Feature for adding or removing sub-shapes from shape. More...
#include <BuildPlugin_SubShapes.h>
| BuildPlugin_SubShapes () | |
| virtual void | execute () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_SHAPE_ID () |
| Attribute name of base shape. More... | |
| static const std::string & | SUBSHAPES_ID () |
| Attribute name of sub-shapes. More... | |
| BuildPlugin_SubShapes::BuildPlugin_SubShapes | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
| [in] | theID | identifier of changed attribute. |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
