SketchPlugin_Offset Class Reference
Builds offset curves in the sketch. More...
#include <SketchPlugin_Offset.h>
Inheritance diagram for SketchPlugin_Offset:
virtual SKETCHPLUGIN_EXPORT const std::string & getKind ()
virtual SKETCHPLUGIN_EXPORT void attributeChanged (const std::string &theID)
virtual SKETCHPLUGIN_EXPORT void execute ()
virtual SKETCHPLUGIN_EXPORT bool isPreviewNeeded () const
virtual SKETCHPLUGIN_EXPORT bool customAction (const std::string &theActionId)
 Find edges connected by coincident boundary constraint and composing a wire with the already selected segments. More...
virtual SKETCHPLUGIN_EXPORT AISObjectPtr getAISObject (AISObjectPtr thePrevious)
 SketchPlugin_Offset ()
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Offset macro feature kind. More...
static const std::string & JOINT_ID ()
 Type of joint. More...
static const std::string & JOINT_KEEP_DISTANCE ()
 Keep distance joint (add arcs where needed) More...
static const std::string & JOINT_ARCS ()
 Arcs joint (make fillets on all straight lines intersections) More...
static const std::string & JOINT_LINES ()
 Lines joint (do not add new arcs, prolongate and intersect adjacent lines) More...
static const std::string & EDGES_ID ()
 list of offset edges More...
static const std::string & VALUE_ID ()
 attribute to store the offset value More...
static const std::string & REVERSED_ID ()
 attribute to store the reversed offset direction More...
static const std::string & APPROX_ID ()
 attribute to approx by segments and arcs More...
static const std::string & ADD_WIRE_ACTION_ID ()
 name for add wire action More...
static std::string group ()
 Initializes attributes of derived class. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
◆ SketchPlugin_Offset()
SketchPlugin_Offset::SketchPlugin_Offset ( )
◆ ID()
static const std::string & SketchPlugin_Offset::ID ( )
inlinestatic
◆ getKind()
virtual SKETCHPLUGIN_EXPORT const std::string & SketchPlugin_Offset::getKind ( )
Implements ModelAPI_Feature.
◆ JOINT_ID()
static const std::string & SketchPlugin_Offset::JOINT_ID ( )
inlinestatic
Type of joint.
◆ JOINT_KEEP_DISTANCE()
static const std::string & SketchPlugin_Offset::JOINT_KEEP_DISTANCE ( )
inlinestatic
◆ JOINT_ARCS()
static const std::string & SketchPlugin_Offset::JOINT_ARCS ( )
inlinestatic
◆ JOINT_LINES()
static const std::string & SketchPlugin_Offset::JOINT_LINES ( )
inlinestatic
◆ EDGES_ID()
static const std::string & SketchPlugin_Offset::EDGES_ID ( )
inlinestatic
◆ VALUE_ID()
static const std::string & SketchPlugin_Offset::VALUE_ID ( )
inlinestatic
◆ REVERSED_ID()
static const std::string & SketchPlugin_Offset::REVERSED_ID ( )
inlinestatic
◆ APPROX_ID()
static const std::string & SketchPlugin_Offset::APPROX_ID ( )
inlinestatic
◆ ADD_WIRE_ACTION_ID()
static const std::string & SketchPlugin_Offset::ADD_WIRE_ACTION_ID ( )
inlinestatic
◆ attributeChanged()
void SketchPlugin_Offset::attributeChanged ( const std::string &  theID)
◆ execute()
void SketchPlugin_Offset::execute ( )
◆ isPreviewNeeded()
virtual SKETCHPLUGIN_EXPORT bool SketchPlugin_Offset::isPreviewNeeded ( ) const
Returns true if preview update during the edition needed.
true by default
◆ customAction()
bool SketchPlugin_Offset::customAction ( const std::string &  theActionId)
It means that not more than 2 edges can be connected with the coincident point.
[in]theActionIdaction key id (in following form: Action::Index)
false in case the action not performed.
◆ getAISObject()
AISObjectPtr SketchPlugin_Offset::getAISObject ( AISObjectPtr  thePrevious)
◆ initAttributes()
void SketchPlugin_Offset::initAttributes ( )
Implements ModelAPI_Object.
◆ VALUE()
inlinestaticinherited
◆ FLYOUT_VALUE_PNT()
◆ CONSTRAINT_ACTIVE()
◆ ENTITY_A()
◆ ENTITY_B()
◆ ENTITY_C()
◆ ENTITY_D()
◆ ATTRIBUTE()
◆ isZeroValueAllowed()
inlinevirtualinherited
◆ setNumericValue()
theValuenew set value
◆ getNumericValue()
◆ isInHistory()
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
