The body (shape) result of a feature. More...
#include <ModelAPI_ResultBody.h>
Public Types | |
| enum | ConnectedTopologyFlag { ConnectionNotComputed , IsConnected , IsNotConnected } |
| Internal enumeration for storage the information of connected topology flag. More... | |
| virtual int | numberOfSubs (bool forTree=false) const =0 |
| Returns the number of sub-elements. More... | |
| virtual std::shared_ptr< ModelAPI_ResultBody > | subResult (const int theIndex, bool forTree=false) const =0 |
| Returns the sub-result by zero-base index. More... | |
| virtual bool | isSub (ObjectPtr theResult, int &theIndex) const =0 |
| Returns true if theResult belong to this composite result as sub. More... | |
| virtual void | store (const GeomShapePtr &theShape, const bool theIsStoreSameShapes=true) |
| Stores the shape (called by the execution method). More... | |
| virtual void | storeGenerated (const GeomShapePtr &theFromShape, const GeomShapePtr &theToShape) |
| Stores the generated shape (called by the execution method). More... | |
| virtual void | storeGenerated (const std::list< GeomShapePtr > &theFromShapes, const GeomShapePtr &theToShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape) |
| Stores the root modified shapes (called by the execution method). More... | |
| virtual void | storeModified (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const bool theIsCleanStored=true) |
| Stores the modified shape (called by the execution method). More... | |
| virtual void | storeModified (const std::list< GeomShapePtr > &theOldShapes, const GeomShapePtr &theNewShape, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape) |
| virtual GeomShapePtr | shape () |
| Returns the shape-result produced by this feature. More... | |
| virtual bool | generated (const GeomShapePtr &theNewShape, const std::string &theName, const bool theCheckIsInResult=true)=0 |
| Records the subshape newShape which was generated during a topological construction. More... | |
| virtual void | generated (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="") |
| Records the shape newShape which was generated from the shape oldShape during a topological construction. More... | |
| virtual void | modified (const GeomShapePtr &theOldShape, const GeomShapePtr &theNewShape, const std::string &theName="") |
| Records the shape newShape which is a modification of the shape oldShape. More... | |
| virtual void | loadDeletedShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const GeomShapePtr &theShapesToExclude=GeomShapePtr()) |
| load deleted shapes More... | |
| virtual void | loadModifiedShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="")=0 |
| load and orient modified shapes More... | |
| virtual void | loadGeneratedShapes (const std::shared_ptr< GeomAlgoAPI_MakeShape > &theAlgo, const GeomShapePtr &theOldShape, const GeomAPI_Shape::ShapeType theShapeTypeToExplore, const std::string &theName="", const bool theSaveOldIfNotInTree=false)=0 |
| load and orient generated shapes More... | |
| virtual void | loadFirstLevel (GeomShapePtr theShape, const std::string &theName)=0 |
| load shapes of the first level (to be used during shape import) More... | |
| virtual bool | isConnectedTopology ()=0 |
| Returns true is the topology is connected. More... | |
| Set displayed flag to the result and all sub results. More... | |
| virtual void | updateSubs (const GeomShapePtr &theThisShape, const bool theShapeChanged=true)=0 |
| Updates the sub-bodies if shape of this object is compsolid or compound. More... | |
| virtual void | updateSubs (const GeomShapePtr &theThisShape, const std::list< GeomShapePtr > &theOlds, const std::shared_ptr< GeomAlgoAPI_MakeShape > theMakeShape, const bool isGenerated)=0 |
| Updates the sub-bodies in accordance to the algorithm history information. More... | |
| virtual void | cleanCash ()=0 |
| Cleans cash related to the already stored elements. More... | |
| virtual std::wstring | addShapeName (std::shared_ptr< GeomAPI_Shape > theShape, const std::wstring &theName)=0 |
| Add shape Name for read shape in step file. More... | |
| virtual void | addShapeColor (const std::wstring &theName, std::vector< int > &theColor)=0 |
| Add color for shape Name read shape in step file. More... | |
| virtual void | setSubShapeColor (const std::shared_ptr< ModelAPI_Result > theResult, const std::shared_ptr< GeomAPI_Shape > theShape, const std::vector< int > &theColor)=0 |
| Add color to sub shape. More... | |
| virtual void | getSubShapeColor (const std::shared_ptr< ModelAPI_Result > theResult, const std::shared_ptr< GeomAPI_Shape > theShape, std::vector< int > &theColor)=0 |
| Get color from sub shape. More... | |
| virtual void | getColoredSubShapes (const std::shared_ptr< ModelAPI_Result > theResult, std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &theColoredShapes)=0 |
| Get colored shapes from result. More... | |
| virtual void | removeSubShapeColors (const std::shared_ptr< ModelAPI_Result > theResult)=0 |
| Forget subshape colors. More... | |
| virtual std::shared_ptr< ModelAPI_AttributeSelection > | selection ()=0 |
| Return Attribute selection. More... | |
| virtual void | setShapeName (std::map< std::wstring, std::shared_ptr< GeomAPI_Shape > > &theShapeName, std::map< std::wstring, std::vector< int > > &theColorsShape)=0 |
| Set the map of name and color read shape in step file. More... | |
| virtual void | clearShapeNameAndColor ()=0 |
| Clear the map of name and color read shape in step file. More... | |
| virtual std::wstring | findShapeName (std::shared_ptr< GeomAPI_Shape > theShape)=0 |
| Find the name of shape read in step file. More... | |
| virtual const std::vector< int > & | findShapeColor (const std::wstring &theShapeName)=0 |
| Find the imported color by the construction name of a shape. More... | |
| virtual void | setSubShapeColorIfAny (const std::shared_ptr< ModelAPI_Result > theResult, const std::shared_ptr< GeomAPI_Shape > theShape)=0 |
| virtual bool | isConcealed () |
| Returns true if the result is concealed from the data tree (referenced by other objects) More... | |
| virtual void | setIsConcealed (const bool theValue, const bool theForced=false) |
| Sets the result as concealed in the data tree (referenced by other objects) More... | |
| virtual bool | setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag) |
| Enables/disables the result. More... | |
| virtual bool | isDisabled () |
| Returns the result is disabled or not. More... | |
| Request for initialization of data model of the result: adding all attributes. More... | |
| Returns all the vertices of this result. More... | |
| Returns all the edges of this result. More... | |
| Returns all the wires of this result. More... | |
| Returns all the faces of this result. More... | |
| Returns all the shells of this result. More... | |
| Returns all the solids of this result. More... | |
| On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More... | |
| static const std::string & | IMAGE_ID () |
| Reference to the image attribute of the result body. More... | |
| static const std::string & | DEFAULT_COLOR () |
| default color for a result body More... | |
| static const std::string | DEFAULT_DEFLECTION () |
| default deflection for a result body More... | |
| static const std::string & | COLOR_ID () |
| Reference to the color of the result. More... | |
| static const std::string & | DEFLECTION_ID () |
| Reference to the deflection of the result. More... | |
| static const std::string & | TRANSPARENCY_ID () |
| Reference to the transparency of the result. More... | |
| static const std::string & | ISO_LINES_ID () |
| static const std::string & | SHOW_ISO_LINES_ID () |
| static const std::string & | SHOW_EDGES_DIRECTION_ID () |
| static const std::string & | BRING_TO_FRONT_ID () |
| Reference to the BringToFront flag of the result. More... | |
| ModelAPI_ResultBody () | |
| Default constructor accessible only from Model_Objects. More... | |
| virtual void | init () |
| virtual void | erase () |
| removes all fields from this feature More... | |
Protected Attributes | |
| ConnectedTopologyFlag | myConnect |
| Keeps (not persistently) the connected topology flag. More... | |
| ModelAPI_BodyBuilder * | myBuilder |
| provides the body processing in naming shape More... | |
| bool | myIsDisabled |
| the result is disabled: removed for the user, but keeps the general info More... | |
Provides a shape that may be displayed in the viewer. May provide really huge results, so, working with this kind of result must be optimized. Also provides a container of sub-body result in case it is compound or compsolid.
protected |
inlinestatic |
Implements ModelAPI_Object.
inlinestatic |
inlinestatic |
inlinestatic |
pure virtual |
Implemented in Model_ResultBody.
pure virtual |
pure virtual |
Returns theIndex - zero based index of sub if found
param[in] theShape shape to store. param[in] theIsStoreSameShapes if false stores reference to the same shape if it is already in document.
Reimplemented from ModelAPI_Result.
pure virtual |
As an example, consider the case of a face generated in construction of a box. Returns true if it is stored correctly (the final shape contains this new sub-shape)
As an example, consider the case of a face generated from an edge in construction of a prism.
As an example, consider the case of a face split or merged in a Boolean operation.
load deleted shapes
pure virtual |
pure virtual |
pure virtual |
pure virtual |
| theDisplay | a boolean value |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
pure virtual |
Returns empty vector if not found.
pure virtual |
inlinestaticinherited |
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
The double value is used. The value is in [0, 1] range
The bool value is used.
Reimplemented in Model_ResultBody, and Model_ResultConstruction.
The disabled result does not participate in any calculation and visualization: like it was removed. But it keeps the general parameters: colors, visibility, etc.
| theThis | pointer to this object, needed to generate all events if it is necessary |
| theFlag | makes disabled if it is true |
Reimplemented in Model_ResultBody, and Model_ResultPart.
Reimplemented in Model_ResultBody, Model_ResultParameter, Model_ResultPart, and ModelAPI_ResultParameter.
protectedvirtualinherited |
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
inlinevirtualinherited |
Reimplemented in ModelAPI_CompositeFeature, ModelAPI_Feature, PartSetPlugin_Part, SketchPlugin_ConstraintMirror, SketchPlugin_MultiRotation, and SketchPlugin_MultiTranslation.
protected |
protected |
protectedinherited |
