SketchPlugin_ConstraintLength Class Reference
Feature for creation of a new constraint which defines a length of a line segment. More...
#include <SketchPlugin_ConstraintLength.h>
Inheritance diagram for SketchPlugin_ConstraintLength:
virtual void execute ()
virtual bool compute (const std::string &theAttributeId)
virtual void colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault)
 SketchPlugin_ConstraintLength ()
bool computeLenghtValue (double &theValue)
 Computes distance between length point attributes. More...
bool isZeroValueAllowed () override
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Length constraint kind. More...
static const std::string & LOCATION_TYPE_ID ()
 attribute name of dimension location type More...
static std::string group ()
void keepCurrentFeature ()
void restoreCurrentFeature ()
This constraint has two attributes: SketchPlugin_Constraint::VALUE() (length) and SketchPlugin_Constraint::ENTITY_A() (segment), SketchPlugin_Constraint::FLYOUT_VALUE_PNT() (distance of a constraints handle)
◆ SketchPlugin_ConstraintLength()
SketchPlugin_ConstraintLength::SketchPlugin_ConstraintLength ( )
◆ ID()
static const std::string & SketchPlugin_ConstraintLength::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_ConstraintLength::getKind ( )
Implements ModelAPI_Feature.
◆ LOCATION_TYPE_ID()
static const std::string & SketchPlugin_ConstraintLength::LOCATION_TYPE_ID ( )
inlinestatic
◆ execute()
void SketchPlugin_ConstraintLength::execute ( )
◆ compute()
bool SketchPlugin_ConstraintLength::compute ( const std::string &  theAttributeId)
◆ initAttributes()
void SketchPlugin_ConstraintLength::initAttributes ( )
Implements ModelAPI_Object.
◆ colorConfigInfo()
void SketchPlugin_ConstraintLength::colorConfigInfo ( std::string &  theSection,
std::string &  theName,
std::string &  theDefault
Returns the parameters of color definition in the resources config manager.
◆ getAISObject()
AISObjectPtr SketchPlugin_ConstraintLength::getAISObject ( AISObjectPtr  thePrevious)
◆ attributeChanged()
void SketchPlugin_ConstraintLength::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ computeLenghtValue()
bool SketchPlugin_ConstraintLength::computeLenghtValue ( double &  theValue)
theValue[out] distance or 0 if one of point attributes is not initialized
boolean value if distance is computed
◆ isZeroValueAllowed()
bool SketchPlugin_ConstraintLength::isZeroValueAllowed ( )
inlineoverridevirtual
Reimplemented from SketchPlugin_Constraint.
◆ VALUE()
inlinestaticinherited
◆ FLYOUT_VALUE_PNT()
◆ CONSTRAINT_ACTIVE()
◆ ENTITY_A()
◆ ENTITY_B()
◆ ENTITY_C()
◆ ENTITY_D()
◆ ATTRIBUTE()
◆ setNumericValue()
inlinevirtualinherited
theValuenew set value
◆ getNumericValue()
◆ isInHistory()
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
