SketchPlugin_MultiTranslation Class Reference
Feature for creation of a number of shifted copies of a list of objects. More...
#include <SketchPlugin_MultiTranslation.h>
Inheritance diagram for SketchPlugin_MultiTranslation:
virtual void execute ()
virtual void erase ()
 SketchPlugin_MultiTranslation ()
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Multi-translation kind. More...
static const std::string & TRANSLATION_LIST_ID ()
 List of objects to be mirrored. More...
static const std::string & VALUE_TYPE ()
 attribute name for first point More...
static const std::string & START_POINT_ID ()
 Start point of translation. More...
static const std::string & END_POINT_ID ()
 End point of translation. More...
static const std::string & NUMBER_OF_OBJECTS_ID ()
 Total number of objects, initial and translated objects. More...
static std::string group ()
void keepCurrentFeature ()
void restoreCurrentFeature ()
This constraint has two attributes: SketchPlugin_Constraint::ENTITY_A() for initial list of objects and SketchPlugin_Constraint::ENTITY_B() for the list of created objects
The list of created objects contains initial and copied objects of each object given. The number copies is the NUMBER_OF_OBJECTS_ID() minus 1. At the start of the list, there are collected N copies of first object from initial list, then N copies of second object etc.
◆ SketchPlugin_MultiTranslation()
SketchPlugin_MultiTranslation::SketchPlugin_MultiTranslation ( )
◆ ID()
static const std::string & SketchPlugin_MultiTranslation::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_MultiTranslation::getKind ( )
Implements ModelAPI_Feature.
◆ TRANSLATION_LIST_ID()
static const std::string & SketchPlugin_MultiTranslation::TRANSLATION_LIST_ID ( )
inlinestatic
◆ VALUE_TYPE()
static const std::string & SketchPlugin_MultiTranslation::VALUE_TYPE ( )
inlinestatic
◆ START_POINT_ID()
static const std::string & SketchPlugin_MultiTranslation::START_POINT_ID ( )
inlinestatic
◆ END_POINT_ID()
static const std::string & SketchPlugin_MultiTranslation::END_POINT_ID ( )
inlinestatic
◆ NUMBER_OF_OBJECTS_ID()
static const std::string & SketchPlugin_MultiTranslation::NUMBER_OF_OBJECTS_ID ( )
inlinestatic
◆ execute()
void SketchPlugin_MultiTranslation::execute ( )
◆ initAttributes()
void SketchPlugin_MultiTranslation::initAttributes ( )
Implements ModelAPI_Object.
◆ attributeChanged()
void SketchPlugin_MultiTranslation::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ getAISObject()
AISObjectPtr SketchPlugin_MultiTranslation::getAISObject ( AISObjectPtr  thePrevious)
◆ erase()
void SketchPlugin_MultiTranslation::erase ( )
◆ VALUE()
inlinestaticinherited
◆ FLYOUT_VALUE_PNT()
◆ CONSTRAINT_ACTIVE()
◆ ENTITY_A()
◆ ENTITY_B()
◆ ENTITY_C()
◆ ENTITY_D()
◆ ATTRIBUTE()
◆ isZeroValueAllowed()
inlinevirtualinherited
◆ setNumericValue()
theValuenew set value
◆ getNumericValue()
◆ isInHistory()
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
