Feature for creation of the new part in PartSet. More...
#include <PartSetPlugin_Part.h>
| virtual const std::string & | getGroup () |
| Returns to which group in the document must be added feature. More... | |
| virtual void | execute () |
| virtual const std::string & | documentToAdd () |
| Part must be added only to PartSet. More... | |
| virtual std::shared_ptr< ModelAPI_Feature > | addFeature (std::string theID) |
| Adds feature to its document. More... | |
| virtual int | numberOfSubs (bool forTree=false) const |
| Returns the number of sub-features of the document. More... | |
| virtual std::shared_ptr< ModelAPI_Feature > | subFeature (const int theIndex, bool forTree=false) |
| Returns the sub-feature by zero-base index. More... | |
| virtual int | subFeatureId (const int theIndex) const |
| Returns the sub-feature unique identifier in this composite feature by zero-base index. More... | |
| virtual bool | isSub (ObjectPtr theObject) const |
| Returns true if feature or result belong to this composite feature as subs. More... | |
| virtual void | removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature) |
| This method to inform that sub-feature is removed and must be removed from the internal data structures of the owner (the remove from the document will be done outside just after) More... | |
| PartSetPlugin_Part () | |
| virtual void | erase () |
| Just removes all features of the part without touching the document data (to be able undo) More... | |
| std::wstring | name () |
| Part kind. More... | |
All sub-features are sub-elements of composite feature.
| PartSetPlugin_Part::PartSetPlugin_Part | ( | ) |
inlinestatic |
Part kind.
inlinevirtual |
Implements ModelAPI_Feature.
inlinevirtual |
Implements ModelAPI_Object.
Implements ModelAPI_CompositeFeature.
inlinevirtual |
Reimplemented from ModelAPI_CompositeFeature.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
