BuildPlugin_Filling Class Reference
Feature for creation of face from list of edges (1D objects). More...
#include <BuildPlugin_Filling.h>
Inheritance diagram for BuildPlugin_Filling:
struct  Method
 Supported methods for edge orientation correction. More...
 BuildPlugin_Filling ()
virtual void execute ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & BASE_OBJECTS_ID ()
 Attribute name of base objects. More...
static const std::string & ADVANCED_OPTIONS_ID ()
 Attribute name of advanced options. More...
static const std::string & METHOD_ID ()
 Attribute name of method of edge orientation. More...
static const std::string & MINIMAL_DEGREE_ID ()
 Attribute name of minimal degree. More...
static const std::string & MAXIMAL_DEGREE_ID ()
 Attribute name of maximal degree. More...
static const std::string & NUMBER_OF_ITERATIONS_ID ()
 Attribute name of number of iterations. More...
static const std::string & TOLERANCE_2D_ID ()
 Attribute name of 2D tolerance. More...
static const std::string & TOLERANCE_3D_ID ()
 Attribute name of 3D tolerance. More...
static const std::string & APPROXIMATION_ID ()
 Attribute name of approximation. More...
static const std::string & METHOD_DEFAULT ()
 Default value of the orientation. More...
static int MINIMAL_DEGREE_DEFAULT ()
 Default value of minimal degree. More...
static int MAXIMAL_DEGREE_DEFAULT ()
 Default value of maximal degree. More...
static int NUMBER_OF_ITERATIONS_DEFAULT ()
 Default value of number of iterations. More...
static double TOLERANCE_2D_DEFAULT ()
 Default value of 2D tolerance. More...
static double TOLERANCE_3D_DEFAULT ()
 Default value of 3D tolerance. More...
static bool APPROXIMATION_DEFAULT ()
 Default value of the approximation attribute. More...
static std::string group ()
◆ BuildPlugin_Filling()
BuildPlugin_Filling::BuildPlugin_Filling ( )
◆ ID()
static const std::string & BuildPlugin_Filling::ID ( )
inlinestatic
Feature kind.
◆ getKind()
virtual const std::string & BuildPlugin_Filling::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ BASE_OBJECTS_ID()
static const std::string & BuildPlugin_Filling::BASE_OBJECTS_ID ( )
inlinestatic
◆ ADVANCED_OPTIONS_ID()
static const std::string & BuildPlugin_Filling::ADVANCED_OPTIONS_ID ( )
inlinestatic
◆ METHOD_ID()
static const std::string & BuildPlugin_Filling::METHOD_ID ( )
inlinestatic
◆ MINIMAL_DEGREE_ID()
static const std::string & BuildPlugin_Filling::MINIMAL_DEGREE_ID ( )
inlinestatic
◆ MAXIMAL_DEGREE_ID()
static const std::string & BuildPlugin_Filling::MAXIMAL_DEGREE_ID ( )
inlinestatic
◆ NUMBER_OF_ITERATIONS_ID()
static const std::string & BuildPlugin_Filling::NUMBER_OF_ITERATIONS_ID ( )
inlinestatic
◆ TOLERANCE_2D_ID()
static const std::string & BuildPlugin_Filling::TOLERANCE_2D_ID ( )
inlinestatic
◆ TOLERANCE_3D_ID()
static const std::string & BuildPlugin_Filling::TOLERANCE_3D_ID ( )
inlinestatic
◆ APPROXIMATION_ID()
static const std::string & BuildPlugin_Filling::APPROXIMATION_ID ( )
inlinestatic
◆ METHOD_DEFAULT()
static const std::string & BuildPlugin_Filling::METHOD_DEFAULT ( )
inlinestatic
◆ MINIMAL_DEGREE_DEFAULT()
static int BuildPlugin_Filling::MINIMAL_DEGREE_DEFAULT ( )
inlinestatic
◆ MAXIMAL_DEGREE_DEFAULT()
static int BuildPlugin_Filling::MAXIMAL_DEGREE_DEFAULT ( )
inlinestatic
◆ NUMBER_OF_ITERATIONS_DEFAULT()
static int BuildPlugin_Filling::NUMBER_OF_ITERATIONS_DEFAULT ( )
inlinestatic
◆ TOLERANCE_2D_DEFAULT()
static double BuildPlugin_Filling::TOLERANCE_2D_DEFAULT ( )
inlinestatic
◆ TOLERANCE_3D_DEFAULT()
static double BuildPlugin_Filling::TOLERANCE_3D_DEFAULT ( )
inlinestatic
◆ APPROXIMATION_DEFAULT()
static bool BuildPlugin_Filling::APPROXIMATION_DEFAULT ( )
inlinestatic
◆ initAttributes()
void BuildPlugin_Filling::initAttributes ( )
Implements ModelAPI_Object.
◆ execute()
void BuildPlugin_Filling::execute ( )
store result
◆ attributeChanged()
void BuildPlugin_Filling::attributeChanged ( const std::string &  theID)
[in]theIDidentifier of changed attribute.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
