SketchPlugin_MacroEllipse Class Reference
Feature for creation of the new ellipse in Sketch. More...
#include <SketchPlugin_MacroEllipse.h>
Inheritance diagram for SketchPlugin_MacroEllipse:
virtual SKETCHPLUGIN_EXPORT const std::string & getKind ()
virtual SKETCHPLUGIN_EXPORT void initAttributes ()
virtual SKETCHPLUGIN_EXPORT void attributeChanged (const std::string &theID)
virtual SKETCHPLUGIN_EXPORT void execute ()
virtual SKETCHPLUGIN_EXPORT bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro(). More...
virtual SKETCHPLUGIN_EXPORT bool isPreviewNeeded () const
virtual std::string processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Apply information of the message to current object. More...
 SketchPlugin_MacroEllipse ()
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Ellipse feature kind. More...
static const std::string & ELLIPSE_TYPE ()
static const std::string & ELLIPSE_TYPE_BY_CENTER_AXIS_POINT ()
static const std::string & ELLIPSE_TYPE_BY_AXIS_AND_POINT ()
static const std::string & EDIT_ELLIPSE_TYPE ()
static const std::string & CENTER_POINT_ID ()
 Attribute for the first point selected during ellipse creation. More...
static const std::string & CENTER_POINT_REF_ID ()
 Reference to the first selected point. More...
static const std::string & MAJOR_AXIS_POINT_ID ()
 Attribute for the second point selected during ellipse creation. More...
static const std::string & MAJOR_AXIS_POINT_REF_ID ()
 Reference to the second selected point. More...
static const std::string & PASSED_POINT_ID ()
 Attribute for the third point selected during ellipse creation. More...
static const std::string & PASSED_POINT_REF_ID ()
 Reference for passed point selection. More...
static const std::string & MAJOR_AXIS_START_ID ()
static const std::string & MAJOR_AXIS_START_REF_ID ()
static const std::string & MAJOR_AXIS_END_ID ()
static const std::string & MAJOR_AXIS_END_REF_ID ()
static const std::string & PASSED_POINT_1_ID ()
static const std::string & PASSED_POINT_1_REF_ID ()
static const std::string & MAJOR_RADIUS_ID ()
 Major radius of the ellipse. More...
static const std::string & MINOR_RADIUS_ID ()
 Minor radius of the ellipse. More...
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of derived class which were added recently. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
◆ SketchPlugin_MacroEllipse()
SketchPlugin_MacroEllipse::SketchPlugin_MacroEllipse ( )
◆ ID()
static const std::string & SketchPlugin_MacroEllipse::ID ( )
inlinestatic
◆ CENTER_POINT_ID()
static const std::string & SketchPlugin_MacroEllipse::CENTER_POINT_ID ( )
inlinestatic
◆ CENTER_POINT_REF_ID()
static const std::string & SketchPlugin_MacroEllipse::CENTER_POINT_REF_ID ( )
inlinestatic
◆ MAJOR_AXIS_POINT_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_AXIS_POINT_ID ( )
inlinestatic
◆ MAJOR_AXIS_POINT_REF_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_AXIS_POINT_REF_ID ( )
inlinestatic
◆ PASSED_POINT_ID()
static const std::string & SketchPlugin_MacroEllipse::PASSED_POINT_ID ( )
inlinestatic
◆ PASSED_POINT_REF_ID()
static const std::string & SketchPlugin_MacroEllipse::PASSED_POINT_REF_ID ( )
inlinestatic
◆ MAJOR_AXIS_START_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_AXIS_START_ID ( )
inlinestatic
◆ MAJOR_AXIS_START_REF_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_AXIS_START_REF_ID ( )
inlinestatic
◆ MAJOR_AXIS_END_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_AXIS_END_ID ( )
inlinestatic
◆ MAJOR_AXIS_END_REF_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_AXIS_END_REF_ID ( )
inlinestatic
◆ PASSED_POINT_1_ID()
static const std::string & SketchPlugin_MacroEllipse::PASSED_POINT_1_ID ( )
inlinestatic
◆ PASSED_POINT_1_REF_ID()
static const std::string & SketchPlugin_MacroEllipse::PASSED_POINT_1_REF_ID ( )
inlinestatic
◆ MAJOR_RADIUS_ID()
static const std::string & SketchPlugin_MacroEllipse::MAJOR_RADIUS_ID ( )
inlinestatic
◆ MINOR_RADIUS_ID()
static const std::string & SketchPlugin_MacroEllipse::MINOR_RADIUS_ID ( )
inlinestatic
◆ getKind()
virtual SKETCHPLUGIN_EXPORT const std::string & SketchPlugin_MacroEllipse::getKind ( )
Implements ModelAPI_Feature.
◆ initAttributes()
void SketchPlugin_MacroEllipse::initAttributes ( )
Reimplemented from SketchPlugin_SketchEntity.
◆ attributeChanged()
void SketchPlugin_MacroEllipse::attributeChanged ( const std::string &  theID)
◆ getAISObject()
AISObjectPtr SketchPlugin_MacroEllipse::getAISObject ( AISObjectPtr  thePrevious)
◆ execute()
void SketchPlugin_MacroEllipse::execute ( )
◆ isMacro()
virtual SKETCHPLUGIN_EXPORT bool SketchPlugin_MacroEllipse::isMacro ( ) const
true
◆ isPreviewNeeded()
virtual SKETCHPLUGIN_EXPORT bool SketchPlugin_MacroEllipse::isPreviewNeeded ( ) const
Returns true if preview update during the edition needed.
true by default
◆ processEvent()
std::string SketchPlugin_MacroEllipse::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
It fills reference object, tangent type and tangent point reference in case of tangent arc
Implements ModelAPI_IReentrant.
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
inlinestaticinherited
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
Reimplemented from SketchPlugin_Feature.
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ initDerivedClassAttributes()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes ( )
◆ initDerivedClassAttributes2()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes2 ( )
Reimplemented in SketchPlugin_Projection.
◆ isInHistory()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
Implements ModelAPI_Object.
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
