CollectionPlugin_Field Class Reference
Feature for selection of sub-shapes of some shapes and assigning data on them. More...
#include <CollectionPlugin_Field.h>
Inheritance diagram for CollectionPlugin_Field:
virtual void execute ()
 Creates a new field result if needed. More...
 Result of fields is created on the fly and don't stored to the document. More...
 CollectionPlugin_Field ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Feature kind. More...
static const std::string & SELECTED_ID ()
 attribute name of selected entities list More...
static const std::string & COMPONENTS_NAMES_ID ()
 attribute name of components titles array More...
static const std::string & STAMPS_ID ()
 attribute name of stamps integer array More...
static const std::string & VALUES_ID ()
 attribute name of list of tables that contain default values (row 0) and the custom values More...
static std::string group ()
There is a set of containers that contains the following data that may be inserted by the user:
Selected sub-shapes (like in Groups). Number of components for each selection. Components names Type of values: Boolean, Integer, Double or String. Number of steps: for each step (indexes are zero-based) the values below are multiplied. Stamp: integer identifier per each step Default values for each components Values for each component and each selected sub-shape: all are of specific type.
◆ CollectionPlugin_Field()
CollectionPlugin_Field::CollectionPlugin_Field ( )
◆ ID()
static const std::string & CollectionPlugin_Field::ID ( )
inlinestatic
Feature kind.
◆ SELECTED_ID()
static const std::string & CollectionPlugin_Field::SELECTED_ID ( )
inlinestatic
◆ COMPONENTS_NAMES_ID()
static const std::string & CollectionPlugin_Field::COMPONENTS_NAMES_ID ( )
inlinestatic
◆ STAMPS_ID()
static const std::string & CollectionPlugin_Field::STAMPS_ID ( )
inlinestatic
◆ VALUES_ID()
static const std::string & CollectionPlugin_Field::VALUES_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & CollectionPlugin_Field::getKind ( )
Implements ModelAPI_Feature.
◆ execute()
void CollectionPlugin_Field::execute ( )
◆ initAttributes()
void CollectionPlugin_Field::initAttributes ( )
Implements ModelAPI_Object.
◆ isPersistentResult()
virtual bool CollectionPlugin_Field::isPersistentResult ( )
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
