FeaturesPlugin_Recover Class Reference
Feature for display of concealed attributes of some feature. More...
#include <FeaturesPlugin_Recover.h>
Inheritance diagram for FeaturesPlugin_Recover:
virtual void execute ()
 FeaturesPlugin_Recover ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Extrusion kind. More...
static const std::string & BASE_FEATURE ()
 Attribute name of base feature. More...
static const std::string & RECOVERED_ENTITIES ()
 Attribute name of recovered results list. More...
static const std::string & METHOD ()
 Attribute name of the type of recover. More...
static const std::string & METHOD_DEFAULT ()
 Value of default method, recovering concealed objects only. More...
static const std::string & METHOD_COMPOUND ()
 Value of method, recovering parent compounds of concealed objects. More...
static std::string group ()
◆ FeaturesPlugin_Recover()
FeaturesPlugin_Recover::FeaturesPlugin_Recover ( )
◆ ID()
static const std::string & FeaturesPlugin_Recover::ID ( )
inlinestatic
Extrusion kind.
◆ BASE_FEATURE()
static const std::string & FeaturesPlugin_Recover::BASE_FEATURE ( )
inlinestatic
◆ RECOVERED_ENTITIES()
static const std::string & FeaturesPlugin_Recover::RECOVERED_ENTITIES ( )
inlinestatic
◆ METHOD()
static const std::string & FeaturesPlugin_Recover::METHOD ( )
inlinestatic
◆ METHOD_DEFAULT()
static const std::string & FeaturesPlugin_Recover::METHOD_DEFAULT ( )
inlinestatic
◆ METHOD_COMPOUND()
static const std::string & FeaturesPlugin_Recover::METHOD_COMPOUND ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_Recover::getKind ( )
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_Recover::execute ( )
◆ initAttributes()
void FeaturesPlugin_Recover::initAttributes ( )
Implements ModelAPI_Object.
◆ attributeChanged()
void FeaturesPlugin_Recover::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
