FeaturesPlugin_SharedFaces Class Reference
Feature to check the shared faces of compsolid or compound. More...
#include <FeaturesPlugin_SharedFaces.h>
Inheritance diagram for FeaturesPlugin_SharedFaces:
virtual FEATURESPLUGIN_EXPORT void execute ()
virtual FEATURESPLUGIN_EXPORT void initAttributes ()
virtual FEATURESPLUGIN_EXPORT void attributeChanged (const std::string &theID)
virtual FEATURESPLUGIN_EXPORT bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro(). Returns true. More...
 FeaturesPlugin_SharedFaces ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Shared faces kind. More...
static const std::string & OBJECT_ID ()
 Attribute name for object selected. More...
static const std::string & NUMBER_FACES_ID ()
 Attribute name for number of faces. More...
static const std::string & LIST_FACES_ID ()
 Attribute name for z coordinate. More...
static const std::string & TRANSPARENCY_ID ()
 Attribute name for transparency. More...
static const std::string & CREATE_GROUP_ID ()
 Attribute name for checkbox create group. More...
static const std::string & COMPUTE_ID ()
 Attribute name for indicate to launch the algo. More...
static const std::string & GROUP_NAME_ID ()
 Attribute name for group name. More...
static std::string group ()
void setFacesGroup (const std::wstring &theName)
void updateFaces ()
GeomShapePtr myShape
◆ FeaturesPlugin_SharedFaces()
FeaturesPlugin_SharedFaces::FeaturesPlugin_SharedFaces ( )
◆ ID()
static const std::string & FeaturesPlugin_SharedFaces::ID ( )
inlinestatic
Shared faces kind.
◆ OBJECT_ID()
static const std::string & FeaturesPlugin_SharedFaces::OBJECT_ID ( )
inlinestatic
◆ NUMBER_FACES_ID()
static const std::string & FeaturesPlugin_SharedFaces::NUMBER_FACES_ID ( )
inlinestatic
◆ LIST_FACES_ID()
static const std::string & FeaturesPlugin_SharedFaces::LIST_FACES_ID ( )
inlinestatic
◆ TRANSPARENCY_ID()
static const std::string & FeaturesPlugin_SharedFaces::TRANSPARENCY_ID ( )
inlinestatic
◆ CREATE_GROUP_ID()
static const std::string & FeaturesPlugin_SharedFaces::CREATE_GROUP_ID ( )
inlinestatic
◆ COMPUTE_ID()
static const std::string & FeaturesPlugin_SharedFaces::COMPUTE_ID ( )
inlinestatic
◆ GROUP_NAME_ID()
static const std::string & FeaturesPlugin_SharedFaces::GROUP_NAME_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_SharedFaces::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_SharedFaces::execute ( )
Reimplemented from FeaturesPlugin_CommonSharedFaces.
◆ initAttributes()
void FeaturesPlugin_SharedFaces::initAttributes ( )
Implements ModelAPI_Object.
◆ attributeChanged()
void FeaturesPlugin_SharedFaces::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ isMacro()
virtual FEATURESPLUGIN_EXPORT bool FeaturesPlugin_SharedFaces::isMacro ( ) const
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
