ExchangePlugin_ImportBase Class Referenceabstract
Inheritance diagram for ExchangePlugin_ImportBase:
 ExchangePlugin_ImportBase ()=default
 Default constructor. More...
virtual ~ExchangePlugin_ImportBase ()=default
 Default destructor. More...
virtual void attributeChanged (const std::string &theID)=0
virtual void execute ()=0
 Computes or recomputes the results. More...
virtual bool isMacro () const
virtual bool isPreviewNeeded () const
 Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More...
virtual const std::string & getKind ()=0
 Returns the unique kind of a feature (like "Point") More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
static const std::string & FILE_PATH_ID ()
 attribute name of file path More...
static const std::string & TARGET_PART_ID ()
 attribute name of target part More...
static const std::string & TARGET_PARTS_LIST_ID ()
 attribute name of list of target parts More...
static std::string group ()
void updatePart (AttributeStringArrayPtr &aPartsAttr, AttributeIntegerPtr &aTargetAttr)
◆ ExchangePlugin_ImportBase()
ExchangePlugin_ImportBase::ExchangePlugin_ImportBase ( )
default
◆ ~ExchangePlugin_ImportBase()
virtual ExchangePlugin_ImportBase::~ExchangePlugin_ImportBase ( )
virtualdefault
Default destructor.
◆ FILE_PATH_ID()
static const std::string & ExchangePlugin_ImportBase::FILE_PATH_ID ( )
inlinestatic
◆ TARGET_PART_ID()
static const std::string & ExchangePlugin_ImportBase::TARGET_PART_ID ( )
inlinestatic
◆ TARGET_PARTS_LIST_ID()
static const std::string & ExchangePlugin_ImportBase::TARGET_PARTS_LIST_ID ( )
inlinestatic
◆ initAttributes()
void ExchangePlugin_ImportBase::initAttributes ( )
Implements ModelAPI_Object.
Reimplemented in ExchangePlugin_Import.
◆ attributeChanged()
virtual void ExchangePlugin_ImportBase::attributeChanged ( const std::string &  theID)
pure virtual
theIDidentifier of changed attribute
Implemented in ExchangePlugin_Import, and ExchangePlugin_Import_Image.
◆ execute()
virtual void ExchangePlugin_ImportBase::execute ( )
pure virtual
Implements ModelAPI_Feature.
◆ isMacro()
virtual bool ExchangePlugin_ImportBase::isMacro ( ) const
Returns true if this feature is used as macro: creates other features and then removed.
◆ isPreviewNeeded()
virtual bool ExchangePlugin_ImportBase::isPreviewNeeded ( ) const
◆ getKind()
virtual const std::string & ModelAPI_Feature::getKind ( )
pure virtualinherited
Implemented in BuildPlugin_Compound, BuildPlugin_CompSolid, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupAddition, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupShape, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportPart, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_Chamfer, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionCut, FeaturesPlugin_ExtrusionFuse, FeaturesPlugin_Fillet, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionCut, FeaturesPlugin_RevolutionFuse, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, FiltersPlugin_Selection, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_Arc, SketchPlugin_BSpline, SketchPlugin_BSplinePeriodic, SketchPlugin_Circle, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceHorizontal, SketchPlugin_ConstraintDistanceVertical, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_CurveFitting, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_Fillet, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroBSplinePeriodic, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Point, SketchPlugin_Projection, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_Split, SketchPlugin_Trim, ExchangePlugin_Import, ExchangePlugin_Import_Image, ExchangePlugin_ImportFeature, ExchangePlugin_Import_ImageFeature, and ExchangePlugin_ImportFeatureBase.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
