Feature for creation of polyline from set of points. More...
#include <BuildPlugin_Polyline.h>
| BuildPlugin_Polyline () | |
| virtual void | execute () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| static const std::string & | CLOSED_ID () |
| Attribute name of closed flag. More... | |
| static bool | CLOSED_DEFAULT () |
| Default value of the closed attribute. More... | |
| BuildPlugin_Polyline::BuildPlugin_Polyline | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
