SketchPlugin_Arc Class Reference
Feature for creation of the new arc of circle in PartSet. More...
#include <SketchPlugin_Arc.h>
Inheritance diagram for SketchPlugin_Arc:
virtual bool isFixed ()
virtual void execute ()
 Creates an arc-shape. More...
void setReversed (bool isReversed)
 Updates the "reversed" flag. More...
bool isReversed ()
 Returns true is the arc is reversed. More...
 SketchPlugin_Arc ()
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Arc feature kind. More...
static const std::string & CENTER_ID ()
 Central 2D point of the circle which contains the arc. More...
static const std::string & START_ID ()
 Start 2D point of the arc. More...
static const std::string & END_ID ()
 End 2D point of the arc. More...
static const std::string & RADIUS_ID ()
 Arc radius. More...
static const std::string & ANGLE_ID ()
 Arc angle. More...
static const std::string & REVERSED_ID ()
 Reversed flag. More...
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of derived class which were added recently. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
The visualization of this object is separated in two parts. The first one is an AIS object calculated when there is non-initialized attributes of the arc. The second is a result and it is calculated if all attributes are initialized.
◆ SketchPlugin_Arc()
SketchPlugin_Arc::SketchPlugin_Arc ( )
◆ ID()
static const std::string & SketchPlugin_Arc::ID ( )
inlinestatic
Arc feature kind.
◆ CENTER_ID()
static const std::string & SketchPlugin_Arc::CENTER_ID ( )
inlinestatic
◆ START_ID()
static const std::string & SketchPlugin_Arc::START_ID ( )
inlinestatic
◆ END_ID()
static const std::string & SketchPlugin_Arc::END_ID ( )
inlinestatic
◆ RADIUS_ID()
static const std::string & SketchPlugin_Arc::RADIUS_ID ( )
inlinestatic
Arc radius.
◆ ANGLE_ID()
static const std::string & SketchPlugin_Arc::ANGLE_ID ( )
inlinestatic
Arc angle.
◆ REVERSED_ID()
static const std::string & SketchPlugin_Arc::REVERSED_ID ( )
inlinestatic
Reversed flag.
◆ getKind()
virtual const std::string & SketchPlugin_Arc::getKind ( )
Implements ModelAPI_Feature.
◆ isFixed()
bool SketchPlugin_Arc::isFixed ( )
Reimplemented from SketchPlugin_Feature.
◆ attributeChanged()
void SketchPlugin_Arc::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ execute()
void SketchPlugin_Arc::execute ( )
◆ setReversed()
void SketchPlugin_Arc::setReversed ( bool  isReversed)
isReversedwhether the arc will be reversed
◆ isReversed()
bool SketchPlugin_Arc::isReversed ( )
◆ initDerivedClassAttributes()
void SketchPlugin_Arc::initDerivedClassAttributes ( )
Reimplemented from SketchPlugin_SketchEntity.
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
inlinestaticinherited
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ initAttributes()
void SketchPlugin_SketchEntity::initAttributes ( )
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ initDerivedClassAttributes2()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes2 ( )
Reimplemented in SketchPlugin_Projection.
◆ isInHistory()
◆ canBeDisplayed()
true
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
