SketchPlugin_Arc.h
20#ifndef SketchPlugin_Arc_H_
21#define SketchPlugin_Arc_H_
23#include "SketchPlugin.h"
24
25#include "SketchPlugin_SketchEntity.h"
26
27
28
37{
38 public:
40 inline static const std::string& ID()
41 {
42 static const std::string ID("SketchArc");
43 return ID;
44 }
45
47 inline static const std::string& CENTER_ID()
48 {
49 static const std::string ID = "center_point";
50 return ID;
51 }
52
54 inline static const std::string& START_ID()
55 {
56 static const std::string ID = "start_point";
57 return ID;
58 }
59
61 inline static const std::string& END_ID()
62 {
63 static const std::string ID = "end_point";
64 return ID;
65 }
66
68 static const std::string& RADIUS_ID()
69 {
70 static const std::string ID("radius");
71 return ID;
72 }
73
75 static const std::string& ANGLE_ID()
76 {
77 static const std::string ID("angle");
78 return ID;
79 }
80
82 inline static const std::string& REVERSED_ID()
83 {
84 static const std::string ID("reversed");
85 return ID;
86 }
87
89 SKETCHPLUGIN_EXPORT virtual const std::string& getKind()
90 {
91 static std::string MY_KIND = SketchPlugin_Arc::ID();
92 return MY_KIND;
93 }
94
96 SKETCHPLUGIN_EXPORT virtual bool isFixed();
97
100 SKETCHPLUGIN_EXPORT virtual void attributeChanged(const std::string& theID);
101
103 SKETCHPLUGIN_EXPORT virtual void execute();
104
107 void setReversed(bool isReversed);
108
110 bool isReversed();
111
114
115protected:
117 virtual void initDerivedClassAttributes();
118
119private:
121 double myParamBefore;
122};
123
124#endif
Feature for creation of the new arc of circle in PartSet.
Definition: SketchPlugin_Arc.h:37
Definition: SketchPlugin_Arc.h:89
static const std::string & CENTER_ID()
Central 2D point of the circle which contains the arc.
Definition: SketchPlugin_Arc.h:47
static const std::string & START_ID()
Start 2D point of the arc.
Definition: SketchPlugin_Arc.h:54
static const std::string & REVERSED_ID()
Reversed flag.
Definition: SketchPlugin_Arc.h:82
virtual void attributeChanged(const std::string &theID)
Definition: SketchPlugin_Arc.cpp:163
Returns true is sketch element is under the rigid constraint.
Definition: SketchPlugin_Arc.cpp:158
Creates an arc-shape.
Definition: SketchPlugin_Arc.cpp:87
Arc radius.
Definition: SketchPlugin_Arc.h:68
Initializes attributes of derived class.
Definition: SketchPlugin_Arc.cpp:66
static const std::string & END_ID()
End 2D point of the arc.
Definition: SketchPlugin_Arc.h:61
static const std::string & ANGLE_ID()
Arc angle.
Definition: SketchPlugin_Arc.h:75
Updates the "reversed" flag.
Definition: SketchPlugin_Arc.cpp:289
bool isReversed()
Returns true is the arc is reversed.
Definition: SketchPlugin_Arc.cpp:294
Arc feature kind.
Definition: SketchPlugin_Arc.h:40
SketchPlugin_Arc()
Definition: SketchPlugin_Arc.cpp:60
Sketch Entity for creation of the new feature in PartSet.
Definition: SketchPlugin_SketchEntity.h:45
