FeaturesPlugin_InspectBoundingBox Class Reference
Feature to view the Bounding Box. More...
#include <FeaturesPlugin_InspectBoundingBox.h>
Inheritance diagram for FeaturesPlugin_InspectBoundingBox:
virtual FEATURESPLUGIN_EXPORT void execute ()
virtual FEATURESPLUGIN_EXPORT void initAttributes ()
virtual FEATURESPLUGIN_EXPORT void attributeChanged (const std::string &theID)
virtual FEATURESPLUGIN_EXPORT bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro(). Returns true. More...
 FeaturesPlugin_InspectBoundingBox ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Bounding box macro kind. More...
static const std::string & OBJECT_ID ()
 Attribute name for object selected. More...
static const std::string & X_MIN_COORD_ID ()
 Attribute name for x coordinate. More...
static const std::string & Y_MIN_COORD_ID ()
 Attribute name for y coordinate. More...
static const std::string & Z_MIN_COORD_ID ()
 Attribute name for z coordinate. More...
static const std::string & X_MAX_COORD_ID ()
 Attribute name for x max coordinate. More...
static const std::string & Y_MAX_COORD_ID ()
 Attribute name for y max coordinate. More...
static const std::string & Z_MAX_COORD_ID ()
 Attribute name for z max coordinate. More...
static const std::string & CREATEBOX_ID ()
 Attribute name for checkbox create box. More...
static const std::string & RESULT_VALUES_ID ()
 Attribute name for values of result. More...
static std::string group ()
void createBoxByTwoPoints ()
 Create box with two points. More...
void loadNamingDS (std::shared_ptr< GeomAlgoAPI_Box > theBoxAlgo, std::shared_ptr< ModelAPI_ResultBody > theResultBox)
 Create namming. More...
GeomShapePtr myShape
◆ FeaturesPlugin_InspectBoundingBox()
FeaturesPlugin_InspectBoundingBox::FeaturesPlugin_InspectBoundingBox ( )
◆ ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::ID ( )
inlinestatic
◆ OBJECT_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::OBJECT_ID ( )
inlinestatic
◆ X_MIN_COORD_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::X_MIN_COORD_ID ( )
inlinestatic
◆ Y_MIN_COORD_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::Y_MIN_COORD_ID ( )
inlinestatic
◆ Z_MIN_COORD_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::Z_MIN_COORD_ID ( )
inlinestatic
◆ X_MAX_COORD_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::X_MAX_COORD_ID ( )
inlinestatic
◆ Y_MAX_COORD_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::Y_MAX_COORD_ID ( )
inlinestatic
◆ Z_MAX_COORD_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::Z_MAX_COORD_ID ( )
inlinestatic
◆ CREATEBOX_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::CREATEBOX_ID ( )
inlinestatic
◆ RESULT_VALUES_ID()
static const std::string & FeaturesPlugin_InspectBoundingBox::RESULT_VALUES_ID ( )
inlinestatic
◆ getKind()
virtual const std::string & FeaturesPlugin_InspectBoundingBox::getKind ( )
the kind of a feature.
Implements ModelAPI_Feature.
◆ execute()
void FeaturesPlugin_InspectBoundingBox::execute ( )
Reimplemented from FeaturesPlugin_BoundingBoxBase.
◆ initAttributes()
void FeaturesPlugin_InspectBoundingBox::initAttributes ( )
Implements ModelAPI_Object.
◆ attributeChanged()
void FeaturesPlugin_InspectBoundingBox::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ isMacro()
virtual FEATURESPLUGIN_EXPORT bool FeaturesPlugin_InspectBoundingBox::isMacro ( ) const
◆ createBoxByTwoPoints()
void FeaturesPlugin_BoundingBoxBase::createBoxByTwoPoints ( )
◆ loadNamingDS()
void FeaturesPlugin_BoundingBoxBase::loadNamingDS ( std::shared_ptr< GeomAlgoAPI_Box >  theBoxAlgo,
Create namming.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
