GeomAlgoAPI_Box Class Reference
Allows to create Box Primitives. More...
#include <GeomAlgoAPI_Box.h>
Inheritance diagram for GeomAlgoAPI_Box:
enum  MethodType { BOX_DIM , BOX_POINTS , BOX_POINT_DIMS }
 Type of box operation. More...
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Box (const double theDx, const double theDy, const double theDz)
 Creates a box using the dimensions. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Box (std::shared_ptr< GeomAPI_Pnt > theFirstPoint, std::shared_ptr< GeomAPI_Pnt > theSecondPoint)
 Creates a box using the two points that defined a diagonal. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Box (const double theOx, const double theOy, const double theOz, const double theDx, const double theDy, const double theDz)
 Creates a box using coordinates of a point (the center of gravity) and the dimensions. More...
GEOMALGOAPI_EXPORT bool check ()
 Checks if data for the box construction is OK. More...
GEOMALGOAPI_EXPORT void build ()
 Builds the box. More...
GEOMALGOAPI_EXPORT void prepareNamingFaces ()
 Prepare the naming (redifined because it is specific for a box). More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ MethodType
BOX_DIM
Box with dimensions.
BOX_POINTS
Box with points.
BOX_POINT_DIMS
Box with coordinates of a point and dimensions.
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Box() [1/3]
GeomAlgoAPI_Box::GeomAlgoAPI_Box ( const double  theDx,
const double  theDy,
const double  theDz
theDxThe dimension on X
theDyThe dimension on Y
theDzThe dimension on Z
◆ GeomAlgoAPI_Box() [2/3]
GeomAlgoAPI_Box::GeomAlgoAPI_Box ( std::shared_ptr< GeomAPI_Pnt >  theFirstPoint,
theFirstPointOne extermity of the diagonal
theSecondPointThe other extremity of the diagonal
◆ GeomAlgoAPI_Box() [3/3]
GeomAlgoAPI_Box::GeomAlgoAPI_Box ( const double  theOx,
const double  theOy,
const double  theOz,
const double  theDx,
const double  theDy,
const double  theDz
theOxThe X coordinate of the point
theOyThe Y coordinate of the point
theOzThe Z coordinate of the point
◆ check()
bool GeomAlgoAPI_Box::check ( )
◆ build()
void GeomAlgoAPI_Box::build ( )
Builds the box.
◆ prepareNamingFaces()
void GeomAlgoAPI_Box::prepareNamingFaces ( )
◆ initialize()
template<class T >
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
