Perform Thickness or Hollowed Solid algorithm for the shape. More...
#include <GeomAlgoAPI_Thickness.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Thickness (const GeomShapePtr &theShape, const double theThickness, const bool isInside) |
| Perform thickening algorithm. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Thickness (const GeomShapePtr &theShape, const ListOfShape &theFaces, const double theThickness, const bool isInside) |
| Perform hollowed solid algorithm. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Thickness::GeomAlgoAPI_Thickness | ( | const GeomShapePtr & | theShape, |
| const double | theThickness, | ||
| const bool | isInside | ||
| [in] | theShape | base shape (Face or Shell) |
| [in] | theThickness | thickness of the resulting solid |
| [in] | isInside | if true, the thickness is applied towards inside |
| const ListOfShape & | theFaces, | ||
| [in] | theShape | base shape (Solid) |
| [in] | theFaces | the list of faces to be removed from the result |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
