This tool tries to unify faces and edges of the shape which lies on the same geometry. More...
#include <GeomAlgoAPI_UnifySameDomain.h>
Public Types | |
| GeomAlgoAPI_UnifySameDomain (const ListOfShape &theShapes) | |
| Constructor. More... | |
| GeomAlgoAPI_UnifySameDomain (const GeomShapePtr &theShape) | |
| virtual void | modified (const std::shared_ptr< GeomAPI_Shape > theShape, ListOfShape &theHistory) |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_UnifySameDomain::GeomAlgoAPI_UnifySameDomain | ( | const ListOfShape & | theShapes | ) |
| GeomAlgoAPI_UnifySameDomain::GeomAlgoAPI_UnifySameDomain | ( | const GeomShapePtr & | theShape | ) |
| [in] | theShape | base shape. |
| [out] | theHistory | modified shapes. |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
