Set of independent topological shapes constructions. More...
#include <GeomAlgoAPI_MakeShapeSet.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_MakeShapeSet () |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_MakeShapeSet (const ListOfMakeShape &theMakeShapeSet) |
| Constructor. More... | |
| virtual GEOMALGOAPI_EXPORT void | generated (const GeomShapePtr theShape, ListOfShape &theHistory) |
| virtual GEOMALGOAPI_EXPORT void | modified (const GeomShapePtr theShape, ListOfShape &theHistory) |
| GEOMALGOAPI_EXPORT void | init (const ListOfMakeShape &theMakeShapeList) |
| Initializes a class with new list of algorithms. More... | |
| GEOMALGOAPI_EXPORT const ListOfMakeShape & | list () const |
| GEOMALGOAPI_EXPORT void | appendAlgo (const GeomMakeShapePtr theMakeShape) |
| Adds algo to the end of list. More... | |
| virtual GEOMALGOAPI_EXPORT bool | isDeleted (const GeomShapePtr theShape) |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| ListOfMakeShape | myListOfMakeShape |
| List of make shape algos. More... | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_MakeShapeSet::GeomAlgoAPI_MakeShapeSet | ( | ) |
| GeomAlgoAPI_MakeShapeSet::GeomAlgoAPI_MakeShapeSet | ( | const ListOfMakeShape & | theMakeShapeSet | ) |
| [in] | theMakeShapeSet | list of algorithms. |
Reimplemented from GeomAlgoAPI_MakeShapeList.
| [in] | theMakeShapeList | list of algorithms. |
| [in] | theMakeShape | algo to be added. |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
