Interface to the root class of all topological shapes constructions. More...
#include <GeomAlgoAPI_MakeShape.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_MakeShape () |
| Empty constructor. More... | |
| GEOMALGOAPI_EXPORT | ~GeomAlgoAPI_MakeShape () |
| Destructor for remove myHist. More... | |
| template<class T > | |
| GeomAlgoAPI_MakeShape (T *theBuilder, const BuilderType theBuilderType=OCCT_BRepBuilderAPI_MakeShape) | |
| Constructor by builder and builder type. More... | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_MakeShape::GeomAlgoAPI_MakeShape | ( | ) |
Empty constructor.
| GeomAlgoAPI_MakeShape::~GeomAlgoAPI_MakeShape | ( | ) |
inlineexplicit |
inline |
inlinevirtual |
| bool GeomAlgoAPI_MakeShape::isDone | ( | ) | const |
| bool GeomAlgoAPI_MakeShape::isValid | ( | ) | const |
| std::shared_ptr< GeomAPI_DataMapOfShapeShape > GeomAlgoAPI_MakeShape::mapOfSubShapes | ( | ) | const |
| void GeomAlgoAPI_MakeShape::modifiedCached | ( | const GeomShapePtr | theOldShape, |
| ListOfShape & | theNewShapes | ||
inlinevirtual |
inline |
inline |
| bool GeomAlgoAPI_MakeShape::checkValid | ( | std::string | theMessage | ) |
| bool GeomAlgoAPI_MakeShape::isNewShapesCollected | ( | GeomShapePtr | theWholeOld, |
| const int | theShapeType | ||
| void GeomAlgoAPI_MakeShape::collectNewShapes | ( | GeomShapePtr | theWholeOld, |
| void GeomAlgoAPI_MakeShape::cleanNewShapes | ( | GeomShapePtr | theWholeOld, |
| GeomShapePtr GeomAlgoAPI_MakeShape::oldShapesForNew | ( | GeomShapePtr | theWholeOld, |
| GeomShapePtr | theNewShape, | ||
| void GeomAlgoAPI_MakeShape::fixOrientation | ( | GeomShapePtr & | theShape | ) |
protected |
Sets builder type.
protected |
protected |
Sets result shape.
protected |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protected |
protected |
protected |
