GeomAlgoAPI_Sewing Class Reference
Allows creation of connected topology (shells) from a set of separate topological elements (faces). More...
#include <GeomAlgoAPI_Sewing.h>
Inheritance diagram for GeomAlgoAPI_Sewing:
 Builder type enum. More...
 GeomAlgoAPI_Sewing (const ListOfShape &theShapes)
 Constructor (used by MakeShell). More...
 GeomAlgoAPI_Sewing (const ListOfShape &theShapes, const bool theAllowNonManifold, const double theTolerance)
 Constructor with additional arguments (used by Sewing feature) More...
virtual void modified (const std::shared_ptr< GeomAPI_Shape > theShape, ListOfShape &theHistory)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
bool myBuildShell
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Sewing() [1/2]
GeomAlgoAPI_Sewing::GeomAlgoAPI_Sewing ( const ListOfShape &  theShapes)
[in]theShapeslist of selected shapes.
◆ GeomAlgoAPI_Sewing() [2/2]
GeomAlgoAPI_Sewing::GeomAlgoAPI_Sewing ( const ListOfShape &  theShapes,
[in]theAllowNonManifoldif True, non-manifold results are allowed.
[in]theTolerancetolerance value used for the sewing operation.
◆ modified()
void GeomAlgoAPI_Sewing::modified ( const std::shared_ptr< GeomAPI_Shape >  theShape,
ListOfShape &  theHistory
the list of shapes modified from the shape theShape.
[in]theShapebase shape.
[out]theHistorymodified shapes.
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
