Allows to create Cone Segment GDML Primitives. More...
#include <GeomAlgoAPI_ConeSegment.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_ConeSegment (const double theRMin1, const double theRMax1, const double theRMin2, const double theRMax2, const double theZ, const double theStartPhi, const double theDeltaPhi) |
| Creates a cone segment using standard GDML parameters. More... | |
| GEOMALGOAPI_EXPORT bool | check () |
| Checks if the set of parameters used to define the cone segment are OK. More... | |
| GEOMALGOAPI_EXPORT void | build () |
| Builds the cone segment based on the parameters given in the constructor. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_ConeSegment::GeomAlgoAPI_ConeSegment | ( | const double | theRMin1, |
| const double | theRMax1, | ||
| const double | theRMin2, | ||
| const double | theRMax2, | ||
| const double | theZ, | ||
| const double | theStartPhi, | ||
| const double | theDeltaPhi | ||
| theRMin1 | Cone base inner radius. |
| theRMax1 | Cone base outer radius. |
| theRMin2 | Cone top inner radius. |
| theRMax2 | Cone top outer radius. |
| theZ | Cone height. |
| theStartPhi | Start angle of the cone segment. |
| theDeltaPhi | Delta angle of the cone segment. |
inlineinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
