Allows to perform of boolean operations. More...
#include <GeomAlgoAPI_Boolean.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Boolean (const GeomShapePtr theObject, const GeomShapePtr theTool, const GeomAlgoAPI_Tools::BOPType theOperationType, const double theFuzzy=-1) |
| Constructor. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Boolean (const GeomShapePtr theObject, const ListOfShape &theTools, const GeomAlgoAPI_Tools::BOPType theOperationType, const double theFuzzy=-1) |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Boolean (const ListOfShape &theObjects, const ListOfShape &theTools, const GeomAlgoAPI_Tools::BOPType theOperationType, const double theFuzzy=-1) |
| Redefinition of the generic method for the Fuse problem: OCCT 30481. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Boolean::GeomAlgoAPI_Boolean | ( | const GeomShapePtr | theObject, |
| const GeomShapePtr | theTool, | ||
| const GeomAlgoAPI_Tools::BOPType | theOperationType, | ||
| const double | theFuzzy = -1 |
| [in] | theObject | the main object. |
| [in] | theTool | the tool object. |
| [in] | theOperationType | type of boolean operation. |
| [in] | theFuzzy | additional tolerance value. If the fuzzy value is non-positive, the boolean operation will use a default |
| const ListOfShape & | theTools, | ||
| [in] | theTools | list of tools. |
| GeomAlgoAPI_Boolean::GeomAlgoAPI_Boolean | ( | const ListOfShape & | theObjects, |
| [in] | theObjects | list of main objects. |
make arguments of Fuse produce result shapes with "modified" evolution
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
