Allows to create Cone Primitives. More...
#include <GeomAlgoAPI_Cone.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Cone (std::shared_ptr< GeomAPI_Ax2 > theAxis, const double theBaseRadius, const double theTopRadius, const double theHeight) |
| Creates a cone. More... | |
| GEOMALGOAPI_EXPORT bool | check () |
| Checks if data for the cone construction is OK. More... | |
| GEOMALGOAPI_EXPORT void | build () |
| Builds the cone. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Cone::GeomAlgoAPI_Cone | ( | std::shared_ptr< GeomAPI_Ax2 > | theAxis, |
| const double | theBaseRadius, | ||
| const double | theTopRadius, | ||
| const double | theHeight | ||
Creates a cone.
| theAxis | The axis of the cone |
| theBaseRadius | The base radius of the cone |
| theTopRadius | The top radius of the cone |
| theHeight | The height of the cone |
Builds the cone.
inlineinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
