Perform fillet on vertices of a wire. More...
#include <GeomAlgoAPI_Fillet1D.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Fillet1D (const GeomShapePtr &theBaseWire, const ListOfShape &theFilletVertices, const double theFilletRadius) |
| Run fillet operation on a set of vertices with fixed radius. More... | |
| const ListOfShape & | failedVertices () const |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Fillet1D::GeomAlgoAPI_Fillet1D | ( | const GeomShapePtr & | theBaseWire, |
| const ListOfShape & | theFilletVertices, | ||
| const double | theFilletRadius | ||
| theBaseWire | a wire or a compound of wires |
| theFilletVertices | list of vertices the fillet is performed on |
| theFilletRadius | radius of the fillet |
| [out] | theNewShapes | shapes modified from theShape. Does not cleared! |
inline |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
