GeomAlgoAPI_Tube Class Reference
Allows to create Tube Primitives. More...
#include <GeomAlgoAPI_Tube.h>
Inheritance diagram for GeomAlgoAPI_Tube:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Tube (const double theRMin, const double theRMax, const double theZ)
 Creates a tube. More...
GEOMALGOAPI_EXPORT bool check ()
 Checks if data for the torus construction is OK. More...
GEOMALGOAPI_EXPORT void build ()
 Builds the torus. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Tube()
GeomAlgoAPI_Tube::GeomAlgoAPI_Tube ( const double  theRMin,
const double  theZ
Creates a tube.
theRMinThe inside radius
theRMaxThe outside radius
theZThe height
◆ check()
bool GeomAlgoAPI_Tube::check ( )
◆ build()
void GeomAlgoAPI_Tube::build ( )
Builds the torus.
◆ initialize()
template<class T >
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
