List of topological shapes constructions. More...
#include <GeomAlgoAPI_MakeShapeList.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_MakeShapeList () |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_MakeShapeList (const ListOfMakeShape &theMakeShapeList) |
| Constructor. More... | |
| GEOMALGOAPI_EXPORT void | init (const ListOfMakeShape &theMakeShapeList) |
| Initializes a class with new list of algorithms. More... | |
| GEOMALGOAPI_EXPORT const ListOfMakeShape & | list () const |
| GEOMALGOAPI_EXPORT void | appendAlgo (const GeomMakeShapePtr theMakeShape) |
| Adds algo to the end of list. More... | |
| virtual GEOMALGOAPI_EXPORT void | generated (const GeomShapePtr theShape, ListOfShape &theHistory) |
| virtual GEOMALGOAPI_EXPORT void | modified (const GeomShapePtr theShape, ListOfShape &theHistory) |
| virtual GEOMALGOAPI_EXPORT bool | isDeleted (const GeomShapePtr theShape) |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| ListOfMakeShape | myListOfMakeShape |
| List of make shape algos. More... | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_MakeShapeList::GeomAlgoAPI_MakeShapeList | ( | ) |
| GeomAlgoAPI_MakeShapeList::GeomAlgoAPI_MakeShapeList | ( | const ListOfMakeShape & | theMakeShapeList | ) |
| [in] | theMakeShapeList | list of algorithms. |
| void GeomAlgoAPI_MakeShapeList::init | ( | const ListOfMakeShape & | theMakeShapeList | ) |
| const ListOfMakeShape & GeomAlgoAPI_MakeShapeList::list | ( | ) | const |
| void GeomAlgoAPI_MakeShapeList::appendAlgo | ( | const GeomMakeShapePtr | theMakeShape | ) |
| [in] | theMakeShape | algo to be added. |
Reimplemented in GeomAlgoAPI_MakeShapeSet, and GeomAlgoAPI_Pipe.
Reimplemented in GeomAlgoAPI_MakeShapeSet.
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protected |
