GeomAlgoAPI_Pipe Class Reference
Allows to create extrusion of objects along a path. More...
#include <GeomAlgoAPI_Pipe.h>
Inheritance diagram for GeomAlgoAPI_Pipe:
 Builder type enum. More...
 GeomAlgoAPI_Pipe (const GeomShapePtr theBaseShape, const GeomShapePtr thePathShape)
 Creates extrusion for the given shape along a path. More...
 GeomAlgoAPI_Pipe (const GeomShapePtr theBaseShape, const GeomShapePtr thePathShape, const GeomShapePtr theBiNormal)
 GeomAlgoAPI_Pipe (const ListOfShape &theBaseShapes, const ListOfShape &theLocations, const GeomShapePtr thePathShape)
void generated (const GeomShapePtr theShape, ListOfShape &theHistory)
GEOMALGOAPI_EXPORT const ListOfShape & fromShapes () const
GEOMALGOAPI_EXPORT const ListOfShape & toShapes () const
GEOMALGOAPI_EXPORT void addFromShape (const std::shared_ptr< GeomAPI_Shape > theShape)
 Adds a shape to list of from shape. More...
GEOMALGOAPI_EXPORT void setFromShapes (const ListOfShape &theListOfShapes)
 Sets from shapes. More...
GEOMALGOAPI_EXPORT void addToShape (const std::shared_ptr< GeomAPI_Shape > theShape)
 Adds a face to list of to shape. More...
GEOMALGOAPI_EXPORT void setToShapes (const ListOfShape &theListOfShapes)
 Sets to shapes. More...
GEOMALGOAPI_EXPORT void init (const ListOfMakeShape &theMakeShapeList)
 Initializes a class with new list of algorithms. More...
GEOMALGOAPI_EXPORT const ListOfMakeShape & list () const
GEOMALGOAPI_EXPORT void appendAlgo (const GeomMakeShapePtr theMakeShape)
 Adds algo to the end of list. More...
virtual GEOMALGOAPI_EXPORT void modified (const GeomShapePtr theShape, ListOfShape &theHistory)
virtual GEOMALGOAPI_EXPORT bool isDeleted (const GeomShapePtr theShape)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
ListOfMakeShape myListOfMakeShape
 List of make shape algos. More...
std::string myError
It produces the following results from objects:
Vertex -> Edge
Edge -> Face
Wire -> Shell
Face -> Solid
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Pipe() [1/3]
GeomAlgoAPI_Pipe::GeomAlgoAPI_Pipe ( const GeomShapePtr  theBaseShape,
[in]theBaseShapebase shape(vertex, edge, wire of face).
[in]thePathShapepath shape(edge or wire).
◆ GeomAlgoAPI_Pipe() [2/3]
[in]theBiNormaledge or wire to preserve the constant angle between the normal vector to the base object and the BiNormal vector.
◆ GeomAlgoAPI_Pipe() [3/3]
GeomAlgoAPI_Pipe::GeomAlgoAPI_Pipe ( const ListOfShape &  theBaseShapes,
const ListOfShape &  theLocations,
[in]theBaseShapesbase shape(vertex, edge, wire of face).
[in]theLocationsvertexes on the path. Should be empty or same size as theBaseShapes.
[in]thePathShapepath shape(edge or wire). to the base object and the BiNormal vector.
◆ generated()
void GeomAlgoAPI_Pipe::generated ( const GeomShapePtr  theShape,
ListOfShape &  theHistory
the list of shapes generated from theShape.
[in]theShapebase shape.
[out]theHistorygenerated shapes.
Reimplemented from GeomAlgoAPI_MakeShapeList.
◆ fromShapes()
const ListOfShape & GeomAlgoAPI_MakeSweep::fromShapes ( ) const
the list of from shapes.
◆ toShapes()
const ListOfShape & GeomAlgoAPI_MakeSweep::toShapes ( ) const
the list of to shapes.
◆ addFromShape()
void GeomAlgoAPI_MakeSweep::addFromShape ( const std::shared_ptr< GeomAPI_Shape >  theShape)
[in]theShapea shape to add.
◆ setFromShapes()
void GeomAlgoAPI_MakeSweep::setFromShapes ( const ListOfShape &  theListOfShapes)
Sets from shapes.
[in]theListOfShapeslist of from shapes.
◆ addToShape()
void GeomAlgoAPI_MakeSweep::addToShape ( const std::shared_ptr< GeomAPI_Shape >  theShape)
[in]theShapea face to add.
◆ setToShapes()
void GeomAlgoAPI_MakeSweep::setToShapes ( const ListOfShape &  theListOfShapes)
Sets to shapes.
[in]theListOfShapeslist of to shapes.
◆ init()
void GeomAlgoAPI_MakeShapeList::init ( const ListOfMakeShape &  theMakeShapeList)
[in]theMakeShapeListlist of algorithms.
◆ list()
const ListOfMakeShape & GeomAlgoAPI_MakeShapeList::list ( ) const
the list reference
◆ appendAlgo()
void GeomAlgoAPI_MakeShapeList::appendAlgo ( const GeomMakeShapePtr  theMakeShape)
[in]theMakeShapealgo to be added.
◆ shape()
const GeomShapePtr GeomAlgoAPI_MakeShapeList::shape ( ) const
a shape built by the shape construction algorithms
◆ modified()
void GeomAlgoAPI_MakeShapeList::modified ( const GeomShapePtr  theShape,
the list of shapes modified from the shape theShape
Reimplemented in GeomAlgoAPI_MakeShapeSet.
◆ isDeleted()
bool GeomAlgoAPI_MakeShapeList::isDeleted ( const GeomShapePtr  theShape)
whether the shape is deleted
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ isValid()
◆ mapOfSubShapes()
◆ modifiedCached()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myListOfMakeShape
ListOfMakeShape GeomAlgoAPI_MakeShapeList::myListOfMakeShape
◆ myMap
◆ myError
◆ myCreatedFaces
