GeomAlgoAPI_MakeSweep Class Reference
The abstract class MakeSweep is the root class of swept primitives. More...
#include <GeomAlgoAPI_MakeSweep.h>
Inheritance diagram for GeomAlgoAPI_MakeSweep:
 Builder type enum. More...
GEOMALGOAPI_EXPORT const ListOfShape & fromShapes () const
GEOMALGOAPI_EXPORT const ListOfShape & toShapes () const
GEOMALGOAPI_EXPORT void addFromShape (const std::shared_ptr< GeomAPI_Shape > theShape)
 Adds a shape to list of from shape. More...
GEOMALGOAPI_EXPORT void setFromShapes (const ListOfShape &theListOfShapes)
 Sets from shapes. More...
GEOMALGOAPI_EXPORT void addToShape (const std::shared_ptr< GeomAPI_Shape > theShape)
 Adds a face to list of to shape. More...
GEOMALGOAPI_EXPORT void setToShapes (const ListOfShape &theListOfShapes)
 Sets to shapes. More...
GEOMALGOAPI_EXPORT void init (const ListOfMakeShape &theMakeShapeList)
 Initializes a class with new list of algorithms. More...
GEOMALGOAPI_EXPORT const ListOfMakeShape & list () const
GEOMALGOAPI_EXPORT void appendAlgo (const GeomMakeShapePtr theMakeShape)
 Adds algo to the end of list. More...
virtual GEOMALGOAPI_EXPORT void generated (const GeomShapePtr theShape, ListOfShape &theHistory)
virtual GEOMALGOAPI_EXPORT void modified (const GeomShapePtr theShape, ListOfShape &theHistory)
virtual GEOMALGOAPI_EXPORT bool isDeleted (const GeomShapePtr theShape)
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 GeomAlgoAPI_MakeSweep ()
 Empty constructor. More...
 Sets builder type. More...
 Sets result shape. More...
ListOfMakeShape myListOfMakeShape
 List of make shape algos. More...
std::string myError
Sweeps are objects you obtain by sweeping a profile along a path. The profile can be any topology and the path is usually a curve or a wire. The profile generates objects according to the following rules:
  • Vertices generate Edges.
  • Edges generate Faces.
  • Wires generate Shells.
  • Faces generate Solids.
  • Shells generate Composite Solids. You are not allowed to sweep Solids and Composite Solids.
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_MakeSweep()
GeomAlgoAPI_MakeSweep::GeomAlgoAPI_MakeSweep ( )
inlineprotected
Empty constructor.
◆ fromShapes()
const ListOfShape & GeomAlgoAPI_MakeSweep::fromShapes ( ) const
the list of from shapes.
◆ toShapes()
const ListOfShape & GeomAlgoAPI_MakeSweep::toShapes ( ) const
the list of to shapes.
◆ addFromShape()
void GeomAlgoAPI_MakeSweep::addFromShape ( const std::shared_ptr< GeomAPI_Shape >  theShape)
[in]theShapea shape to add.
◆ setFromShapes()
void GeomAlgoAPI_MakeSweep::setFromShapes ( const ListOfShape &  theListOfShapes)
Sets from shapes.
[in]theListOfShapeslist of from shapes.
◆ addToShape()
void GeomAlgoAPI_MakeSweep::addToShape ( const std::shared_ptr< GeomAPI_Shape >  theShape)
[in]theShapea face to add.
◆ setToShapes()
void GeomAlgoAPI_MakeSweep::setToShapes ( const ListOfShape &  theListOfShapes)
Sets to shapes.
[in]theListOfShapeslist of to shapes.
◆ init()
void GeomAlgoAPI_MakeShapeList::init ( const ListOfMakeShape &  theMakeShapeList)
[in]theMakeShapeListlist of algorithms.
◆ list()
const ListOfMakeShape & GeomAlgoAPI_MakeShapeList::list ( ) const
the list reference
◆ appendAlgo()
void GeomAlgoAPI_MakeShapeList::appendAlgo ( const GeomMakeShapePtr  theMakeShape)
[in]theMakeShapealgo to be added.
◆ shape()
const GeomShapePtr GeomAlgoAPI_MakeShapeList::shape ( ) const
a shape built by the shape construction algorithms
◆ generated()
void GeomAlgoAPI_MakeShapeList::generated ( const GeomShapePtr  theShape,
ListOfShape &  theHistory
the list of shapes generated from the shape theShape
Reimplemented in GeomAlgoAPI_MakeShapeSet, and GeomAlgoAPI_Pipe.
◆ modified()
void GeomAlgoAPI_MakeShapeList::modified ( const GeomShapePtr  theShape,
the list of shapes modified from the shape theShape
Reimplemented in GeomAlgoAPI_MakeShapeSet.
◆ isDeleted()
bool GeomAlgoAPI_MakeShapeList::isDeleted ( const GeomShapePtr  theShape)
whether the shape is deleted
◆ initialize()
template<class T >
◆ build()
inlinevirtualinherited
◆ isDone()
status of builder.
◆ isValid()
◆ mapOfSubShapes()
◆ modifiedCached()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ check()
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myListOfMakeShape
ListOfMakeShape GeomAlgoAPI_MakeShapeList::myListOfMakeShape
◆ myMap
◆ myError
◆ myCreatedFaces
