Allows to create Sphere Primitives. More...
#include <GeomAlgoAPI_Sphere.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Sphere (std::shared_ptr< GeomAPI_Pnt > theCenterPoint, const double theRadius) |
| Creates a sphere. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Sphere (const double theRMin, const double theRMax, const double thePhiMin, const double thePhiMax, const double theThetaMin, const double theThetaMax) |
| GEOMALGOAPI_EXPORT bool | check () |
| Checks if data for the sphere construction is OK. More... | |
| GEOMALGOAPI_EXPORT void | build () |
| Builds the sphere. More... | |
| GEOMALGOAPI_EXPORT void | buildRootSphere () |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Sphere::GeomAlgoAPI_Sphere | ( | std::shared_ptr< GeomAPI_Pnt > | theCenterPoint, |
| const double | theRadius | ||
Creates a sphere.
| theCenterPoint | The center point of the sphere |
| theRadius | The radius of the sphere |
| GeomAlgoAPI_Sphere::GeomAlgoAPI_Sphere | ( | const double | theRMin, |
| const double | theRMax, | ||
| const double | thePhiMin, | ||
| const double | thePhiMax, | ||
| const double | theThetaMin, | ||
| const double | theThetaMax | ||
Creates a sphere.
| theRMin | The inner radius of the sphere |
| theRMax | The outer radius of the sphere |
| thePhiMin | The lower phi limit |
| thePhiMax | The higher phi limit |
| theThetaMin | The lower theta limit |
| theThetaMax | The higher theta limit |
Builds the sphere.
| void GeomAlgoAPI_Sphere::buildRootSphere | ( | ) |
Builds the sphere.
inlineinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
