Perform 3D offset for the shape. More...
#include <GeomAlgoAPI_Offset.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Offset (const GeomShapePtr &theShape, const double theOffsetValue) |
| Perform simple offset. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Offset (const GeomShapePtr &theShape, const double theOffsetValue, const bool isPipeJoint) |
| Perform 3d offset algorithm. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Offset (const GeomShapePtr &theShape, const ListOfShape &theFaces, const double theOffsetValue) |
| Perform partial 3d offset algorithm. More... | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_Offset (const std::shared_ptr< GeomAPI_Pln > &thePlane, const GeomShapePtr &theEdgeOrWire, const double theOffsetValue, const GeomAlgoAPI_OffsetJoint theJoint=GeomAlgoAPI_OffsetJoint::KeepDistance, const bool theIsApprox=false) |
| Perform 2d offset algorithm on the plane. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_Offset::GeomAlgoAPI_Offset | ( | const GeomShapePtr & | theShape, |
| const double | theOffsetValue | ||
| [in] | theShape | base shape |
| [in] | theOffsetValue | offset distance, it can be negative |
| const double | theOffsetValue, | ||
| const bool | isPipeJoint | ||
| [in] | isPipeJoint | type of joint of faces (pipes or intersections) |
| const ListOfShape & | theFaces, | ||
| [in] | theFaces | list of faces to be offset |
| [in] | theOffsetValue | offset distance for selected faces, it can be negative |
| GeomAlgoAPI_Offset::GeomAlgoAPI_Offset | ( | const std::shared_ptr< GeomAPI_Pln > & | thePlane, |
| const GeomShapePtr & | theEdgeOrWire, | ||
| const GeomAlgoAPI_OffsetJoint | theJoint = GeomAlgoAPI_OffsetJoint::KeepDistance, |
| const bool | theIsApprox = false |
| [in] | thePlane | base plane for all offsets |
| [in] | theEdgesOrWire | base shapes |
| [in] | theJointType | type of joint of straight edges |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
