Perform building solid (compsolid) from a list of faces. More...
#include <GeomAlgoAPI_MakeVolume.h>
Public Types | |
| GEOMALGOAPI_EXPORT | GeomAlgoAPI_MakeVolume (const ListOfShape &theFaces, const bool theAvoidInternal) |
| Constructor. More... | |
| template<class T > | |
| T * | implPtr () |
| const T & | impl () const |
| static GEOMALGOAPI_EXPORT std::shared_ptr< GeomAPI_Shape > | make (const ListOfShape &theFaces) |
| Perform making volume. More... | |
Protected Attributes | |
| std::string | myError |
Builder type enum.
| GeomAlgoAPI_MakeVolume::GeomAlgoAPI_MakeVolume | ( | const ListOfShape & | theFaces, |
| const bool | theAvoidInternal | ||
| theFaces | faces that will construct a solid |
| theAvoidInternal | to remove internal faces from the result |
static |
| [in] | theObjects | list of faces. |
| [out] | theNewShapes | shapes modified from theShape. Does not cleared! |
inlineinherited |
inlinevirtualinherited |
inlineinherited |
inlineinherited |
protectedinherited |
Sets builder type.
Sets result shape.
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
