GeomAlgoAPI_Cylinder Class Reference
Allows to create Cylinder Primitives. More...
#include <GeomAlgoAPI_Cylinder.h>
Inheritance diagram for GeomAlgoAPI_Cylinder:
 Builder type enum. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Cylinder (std::shared_ptr< GeomAPI_Ax2 > theAxis, const double theRadius, const double theHeight)
 Creates a cylinder. More...
GEOMALGOAPI_EXPORT GeomAlgoAPI_Cylinder (std::shared_ptr< GeomAPI_Ax2 > theAxis, const double theRadius, const double theHeight, const double theAngle)
GEOMALGOAPI_EXPORT bool check ()
 Checks if data for the cylinder construction is OK. More...
GEOMALGOAPI_EXPORT void build ()
 Builds the cylinder. More...
template<class T >
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
 Sets builder type. More...
 Sets result shape. More...
std::string myError
◆ BuilderType
Builder type enum.
◆ GeomAlgoAPI_Cylinder() [1/2]
GeomAlgoAPI_Cylinder::GeomAlgoAPI_Cylinder ( std::shared_ptr< GeomAPI_Ax2 >  theAxis,
Creates a cylinder.
theAxisThe axis of the cylinder
theRadiusThe radius of the cylinder
theHeightThe height of the cylinder
◆ GeomAlgoAPI_Cylinder() [2/2]
Creates a cylinder.
theAngleThe covering angle of the cylinder
◆ check()
bool GeomAlgoAPI_Cylinder::check ( )
◆ build()
void GeomAlgoAPI_Cylinder::build ( )
◆ initialize()
template<class T >
◆ isDone()
status of builder.
◆ shape()
◆ isValid()
◆ mapOfSubShapes()
◆ generated()
ListOfShape &  theNewShapes
[in]theOldShapebase shape.
◆ modified()
◆ modifiedCached()
◆ isDeleted()
true if theShape was deleted.
◆ prepareNamingFaces()
◆ getCreatedFaces()
the list of created faces.
◆ getError()
the error.
◆ checkValid()
◆ isNewShapesCollected()
◆ collectNewShapes()
◆ cleanNewShapes()
◆ oldShapesForNew()
◆ fixOrientation()
◆ setBuilderType()
Sets builder type.
◆ setDone()
[in]theFlagnew status.
◆ setShape()
Sets result shape.
[in]theShapenew shape.
◆ isValidForHistory()
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
◆ myMap
◆ myError
◆ myCreatedFaces
