GeomAlgoAPI_Cylinder.h
20#ifndef GEOMALGOAPI_CYLINDER_H_
21#define GEOMALGOAPI_CYLINDER_H_
23#include <GeomAlgoAPI_MakeShape.h>
24
25#include <GeomAPI_Ax2.h>
26#include <GeomAPI_Pnt.h>
27
33{
34 public:
39 GEOMALGOAPI_EXPORT GeomAlgoAPI_Cylinder(std::shared_ptr<GeomAPI_Ax2> theAxis,
40 const double theRadius,
41 const double theHeight);
42
48 GEOMALGOAPI_EXPORT GeomAlgoAPI_Cylinder(std::shared_ptr<GeomAPI_Ax2> theAxis,
49 const double theRadius,
50 const double theHeight,
51 const double theAngle);
52
54 GEOMALGOAPI_EXPORT bool check();
55
57 GEOMALGOAPI_EXPORT void build();
58
59 private:
60 bool withAngle;
61 std::shared_ptr<GeomAPI_Pnt> myBasePoint;
62 std::shared_ptr<GeomAPI_Ax2> myAxis;
63 double myRadius;
64 double myHeight;
65 double myAngle;
66};
67
68
69#endif // GEOMALGOAPI_CYLINDER_H_
Allows to create Cylinder Primitives.
Definition: GeomAlgoAPI_Cylinder.h:33
GEOMALGOAPI_EXPORT GeomAlgoAPI_Cylinder(std::shared_ptr< GeomAPI_Ax2 > theAxis, const double theRadius, const double theHeight)
Creates a cylinder.
Definition: GeomAlgoAPI_Cylinder.cpp:30
Builds the cylinder.
Definition: GeomAlgoAPI_Cylinder.cpp:82
Checks if data for the cylinder construction is OK.
Definition: GeomAlgoAPI_Cylinder.cpp:54
Interface to the root class of all topological shapes constructions.
Definition: GeomAlgoAPI_MakeShape.h:35
