Feature for export some results of a Part to the binary format for the further import. More...
#include <ExchangePlugin_ExportPart.h>
| ExchangePlugin_ExportPart () | |
| virtual EXCHANGEPLUGIN_EXPORT const std::string & | getKind () |
| Returns the unique kind of a feature. More... | |
| virtual EXCHANGEPLUGIN_EXPORT void | initAttributes () |
| virtual EXCHANGEPLUGIN_EXPORT void | execute () |
| virtual EXCHANGEPLUGIN_EXPORT bool | isMacro () const |
| virtual EXCHANGEPLUGIN_EXPORT bool | isPreviewNeeded () const |
| Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More... | |
| bool | isInHistory () |
| Do not put in history. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | FILE_PATH_ID () |
| attribute name of file path More... | |
| static const std::string & | FILE_FORMAT_ID () |
| attribute name of file format More... | |
| static const std::string & | SELECTION_LIST_ID () |
| attribute name of selection list More... | |
| ExchangePlugin_ExportPart::ExchangePlugin_ExportPart | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinevirtual |
inlinevirtual |
inlinevirtual |
Since it is not a macro, it is not deleted, but we don't want to see it.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
