| ExchangePlugin_Import ()=default | |
| virtual | ~ExchangePlugin_Import ()=default |
| Default destructor. More... | |
| virtual const std::string & | getKind () override |
| Returns the unique kind of a feature. More... | |
| virtual void | execute () override |
| virtual void | attributeChanged (const std::string &theID) override |
| virtual bool | isMacro () const |
| virtual bool | isPreviewNeeded () const |
| Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | IMPORT_TYPE_ID () |
| static const std::string & | STEP_FILE_PATH_ID () |
| attribute name of step file path More... | |
| static const std::string & | STEP_TARGET_PART_ID () |
| attribute name of step target part More... | |
| static const std::string & | STEP_TARGET_PARTS_LIST_ID () |
| attribute name of list ofstep target parts More... | |
| static const std::string & | STEP_SCALE_INTER_UNITS_ID () |
| attribute name of step Scale to International System Units More... | |
| static const std::string & | STEP_MATERIALS_ID () |
| attribute name of step materiels More... | |
| static const std::string & | STEP_COLORS_ID () |
| attribute name of step colors More... | |
| static const std::string & | FILE_PATH_ID () |
| attribute name of file path More... | |
| static const std::string & | TARGET_PART_ID () |
| attribute name of target part More... | |
| static const std::string & | TARGET_PARTS_LIST_ID () |
| attribute name of list of target parts More... | |
| void | updatePart (AttributeStringArrayPtr &aPartsAttr, AttributeIntegerPtr &aTargetAttr) |
default |
virtualdefault |
Default destructor.
inlinestatic |
Feature kind.
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlineoverridevirtual |
Implements ModelAPI_Feature.
overridevirtual |
Implements ExchangePlugin_ImportBase.
Reimplemented from ExchangePlugin_ImportBase.
overridevirtual |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
Implements ModelAPI_Object.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
