SketchPlugin_Sketch Class Reference
Feature for creation of the new part in PartSet. More...
#include <SketchPlugin_Sketch.h>
Inheritance diagram for SketchPlugin_Sketch:
virtual void execute ()
std::shared_ptr< GeomAPI_Pnt > to3D (const double theX, const double theY) const
 Converts a 2D sketch space point into point in 3D space. More...
std::shared_ptr< GeomAPI_Pnt2d > to2D (const std::shared_ptr< GeomAPI_Pnt > &thePnt) const
 Returns the point projected into the sketch plane. More...
virtual bool isInHistory ()
 SketchPlugin_Sketch ()
std::shared_ptr< GeomAPI_Pln > plane () const
 Returns the basis plane for the sketch. More...
std::shared_ptr< GeomAPI_Ax3 > coordinatePlane () const
 Returns currently defined plane as an object of Ax3. More...
bool isPlaneSet () const
 Checks whether the plane is set in the sketch. More...
virtual std::shared_ptr< ModelAPI_Feature > addFeature (std::string theID)
 appends a feature to the sketch sub-elements container More...
virtual void removeFeature (std::shared_ptr< ModelAPI_Feature > theFeature)
 Just to synchronise the container of sub-features. More...
virtual int numberOfSubs (bool forTree=false) const
 Returns the number of sub-elements. More...
virtual std::shared_ptr< ModelAPI_Feature > subFeature (const int theIndex, bool forTree=false)
 Returns the sub-feature by zero-base index. More...
virtual int subFeatureId (const int theIndex) const
 Returns the sub-feature unique identifier in this composite feature by index. More...
virtual bool isSub (ObjectPtr theObject) const
 Returns true if feature or result belong to this composite feature as subs. More...
virtual bool customAction (const std::string &theActionId)
virtual void erase ()
 in addition removes all subs More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Sketch feature kind. More...
static const std::string & ORIGIN_ID ()
 Origin point of the sketcher in 3D space. More...
static const std::string & DIRX_ID ()
 Vector X inside of the sketch plane. More...
static const std::string & NORM_ID ()
 Vector Z, normal to the sketch plane. More...
static const std::string & DEFAULT_SIZE_ID ()
 Size of a skectch, if it has just been created on a default plane. More...
static const std::string & AXES_ENABLED_ID ()
static const std::string & SUBSTRATE_ENABLED_ID ()
static const std::string & CONSTRUCTION_GRID_TYPE_ID ()
static const std::string & RECTANGULAR_CONSTRUCTION_GRID_STEP_X_ID ()
static const std::string & RECTANGULAR_CONSTRUCTION_GRID_STEP_Y_ID ()
static const std::string & RECTANGULAR_CONSTRUCTION_GRID_OFFSET_ANGLE_ID ()
static const std::string & RECTANGULAR_CONSTRUCTION_GRID_OFFSET_X_ID ()
static const std::string & RECTANGULAR_CONSTRUCTION_GRID_OFFSET_Y_ID ()
static const std::string & CIRCULAR_CONSTRUCTION_GRID_STEP_R_ID ()
static const std::string & CIRCULAR_CONSTRUCTION_GRID_NUM_OF_ANG_SEGMENTS_ID ()
static const std::string & CIRCULAR_CONSTRUCTION_GRID_OFFSET_ANGLE_ID ()
static const std::string & CIRCULAR_CONSTRUCTION_GRID_OFFSET_X_ID ()
static const std::string & CIRCULAR_CONSTRUCTION_GRID_OFFSET_Y_ID ()
static const std::string & FEATURES_ID ()
 All features of this sketch (list of references) More...
static const std::string & SOLVER_ERROR ()
 Sketch solver error. More...
static const std::string & SOLVER_DOF ()
static const std::string & ACTION_REMOVE_EXTERNAL ()
 Action ID to remove links to external entities while changing the sketch plane. More...
static void createPoint2DResult (ModelAPI_Feature *theFeature, SketchPlugin_Sketch *theSketch, const std::string &theAttributeID, const int theIndex)
 Create a result for the point in the attribute if the attribute is initialized. More...
static void createLine2DResult (ModelAPI_Feature *theFeature, SketchPlugin_Sketch *theSketch, const std::string &theStartAttrID, const std::string &theEndAttrID, const int theIndex=0)
 Create a result for the segment given by a pair of attributes. More...
static FeaturePtr addUniqueNamedCopiedFeature (FeaturePtr theFeature, SketchPlugin_Sketch *theSketch, const bool theIsCopy=false)
 Add new feature and fill the data of the feature by the data of the parameter feature. More...
static std::shared_ptr< GeomAPI_Ax3 > plane (SketchPlugin_Sketch *theSketch)
 Creates a plane of the sketch. More...
static std::string group ()
◆ SketchPlugin_Sketch()
SketchPlugin_Sketch::SketchPlugin_Sketch ( )
◆ ID()
static const std::string & SketchPlugin_Sketch::ID ( )
inlinestatic
◆ ORIGIN_ID()
static const std::string & SketchPlugin_Sketch::ORIGIN_ID ( )
inlinestatic
◆ DIRX_ID()
static const std::string & SketchPlugin_Sketch::DIRX_ID ( )
inlinestatic
◆ NORM_ID()
static const std::string & SketchPlugin_Sketch::NORM_ID ( )
inlinestatic
◆ DEFAULT_SIZE_ID()
static const std::string & SketchPlugin_Sketch::DEFAULT_SIZE_ID ( )
inlinestatic
◆ FEATURES_ID()
static const std::string & SketchPlugin_Sketch::FEATURES_ID ( )
inlinestatic
◆ SOLVER_ERROR()
static const std::string & SketchPlugin_Sketch::SOLVER_ERROR ( )
inlinestatic
◆ SOLVER_DOF()
static const std::string & SketchPlugin_Sketch::SOLVER_DOF ( )
inlinestatic
◆ ACTION_REMOVE_EXTERNAL()
static const std::string & SketchPlugin_Sketch::ACTION_REMOVE_EXTERNAL ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_Sketch::getKind ( )
Implements ModelAPI_Feature.
◆ execute()
void SketchPlugin_Sketch::execute ( )
◆ initAttributes()
void SketchPlugin_Sketch::initAttributes ( )
Implements ModelAPI_Object.
◆ to3D()
std::shared_ptr< GeomAPI_Pnt > SketchPlugin_Sketch::to3D ( const double  theX,
const double  theY
theXan X coordinate
theYan Y coordinate
◆ to2D()
std::shared_ptr< GeomAPI_Pnt2d > SketchPlugin_Sketch::to2D ( const std::shared_ptr< GeomAPI_Pnt > &  thePnt) const
thePnta source 3d point
◆ isInHistory()
virtual bool SketchPlugin_Sketch::isInHistory ( )
◆ plane() [1/2]
std::shared_ptr< GeomAPI_Pln > SketchPlugin_Sketch::plane ( ) const
◆ coordinatePlane()
std::shared_ptr< GeomAPI_Ax3 > SketchPlugin_Sketch::coordinatePlane ( ) const
◆ isPlaneSet()
bool SketchPlugin_Sketch::isPlaneSet ( ) const
the boolean state
◆ addFeature()
std::shared_ptr< ModelAPI_Feature > SketchPlugin_Sketch::addFeature ( std::string  theID)
Implements ModelAPI_CompositeFeature.
◆ removeFeature()
void SketchPlugin_Sketch::removeFeature ( std::shared_ptr< ModelAPI_Feature >  theFeature)
◆ numberOfSubs()
int SketchPlugin_Sketch::numberOfSubs ( bool  forTree = false) const
◆ subFeature()
std::shared_ptr< ModelAPI_Feature > SketchPlugin_Sketch::subFeature ( const int  theIndex,
◆ subFeatureId()
int SketchPlugin_Sketch::subFeatureId ( const int  theIndex) const
◆ isSub()
bool SketchPlugin_Sketch::isSub ( ObjectPtr  theObject) const
◆ attributeChanged()
void SketchPlugin_Sketch::attributeChanged ( const std::string &  theID)
theIDidentifier of changed attribute
◆ customAction()
bool SketchPlugin_Sketch::customAction ( const std::string &  theActionId)
theActionIdan action key
◆ createPoint2DResult()
void SketchPlugin_Sketch::createPoint2DResult ( ModelAPI_Feature *  theFeature,
SketchPlugin_Sketch *  theSketch,
const std::string &  theAttributeID,
const int  theIndex
theFeaturea source feature
theSketcha sketch intance
theAttributeIDan attribute string
theIndexan index of the result
◆ createLine2DResult()
void SketchPlugin_Sketch::createLine2DResult ( ModelAPI_Feature *  theFeature,
const std::string &  theStartAttrID,
const std::string &  theEndAttrID,
const int  theIndex = 0
theStartAttrIDan attribute string
theEndAttrIDan attribute string
◆ addUniqueNamedCopiedFeature()
FeaturePtr SketchPlugin_Sketch::addUniqueNamedCopiedFeature ( FeaturePtr  theFeature,
const bool  theIsCopy = false
The name of the created feature stays unique.
theIsCopyif true sets feature copy attribute to true.
a created feature
◆ plane() [2/2]
std::shared_ptr< GeomAPI_Ax3 > SketchPlugin_Sketch::plane ( SketchPlugin_Sketch *  theSketch)
◆ erase()
void ModelAPI_CompositeFeature::erase ( )
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
