The fields result. More...
#include <ModelAPI_ResultField.h>
Data Structures | |
| class | ModelAPI_FieldStep |
| virtual int | stepsSize () const =0 |
| Returns number of steps. More... | |
| virtual std::string | textLine (int theLine) const =0 |
| Returns a text line by its number. More... | |
| virtual std::shared_ptr< ModelAPI_ResultField::ModelAPI_FieldStep > | step (int theId) const =0 |
| Returns step object. More... | |
| virtual void | updateSteps ()=0 |
| To refresh the steps of a field. More... | |
| virtual bool | isConcealed () |
| Returns true if the result is concealed from the data tree (referenced by other objects) More... | |
| virtual void | setIsConcealed (const bool theValue, const bool theForced=false) |
| Sets the result as concealed in the data tree (referenced by other objects) More... | |
| virtual bool | setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag) |
| Enables/disables the result. More... | |
| virtual bool | isDisabled () |
| Returns the result is disabled or not. More... | |
| Request for initialization of data model of the result: adding all attributes. More... | |
| virtual std::shared_ptr< GeomAPI_Shape > | shape () |
| Returns the shape-result produced by this feature (or null if no shapes) More... | |
| Returns all the vertices of this result. More... | |
| Returns all the edges of this result. More... | |
| Returns all the wires of this result. More... | |
| Returns all the faces of this result. More... | |
| Returns all the shells of this result. More... | |
| Returns all the solids of this result. More... | |
| On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More... | |
| static const std::string & | DEFAULT_COLOR () |
| default color for a result body More... | |
| static const std::string & | COLOR_ID () |
| Reference to the color of the result. More... | |
| static const std::string & | DEFLECTION_ID () |
| Reference to the deflection of the result. More... | |
| static const std::string & | TRANSPARENCY_ID () |
| Reference to the transparency of the result. More... | |
| static const std::string & | ISO_LINES_ID () |
| static const std::string & | SHOW_ISO_LINES_ID () |
| static const std::string & | SHOW_EDGES_DIRECTION_ID () |
| static const std::string & | BRING_TO_FRONT_ID () |
| Reference to the BringToFront flag of the result. More... | |
| virtual void | init () |
| virtual void | erase () |
| removes all fields from this feature More... | |
Protected Attributes | |
| bool | myIsDisabled |
| the result is disabled: removed for the user, but keeps the general info More... | |
The fields result.
Provides a compound of selected elements, without storage, one the fly.
Implements ModelAPI_Object.
inlinestatic |
inlinestatic |
pure virtual |
Implemented in Model_ResultField.
pure virtual |
| theLine | a number of line |
pure virtual |
pure virtual |
inlinestaticinherited |
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
The double value is used. The value is in [0, 1] range
The bool value is used.
Reimplemented in Model_ResultBody, and Model_ResultConstruction.
The disabled result does not participate in any calculation and visualization: like it was removed. But it keeps the general parameters: colors, visibility, etc.
| theThis | pointer to this object, needed to generate all events if it is necessary |
| theFlag | makes disabled if it is true |
Reimplemented in Model_ResultBody, and Model_ResultPart.
Reimplemented in Model_ResultBody, Model_ResultParameter, Model_ResultPart, and ModelAPI_ResultParameter.
Reimplemented in Model_ResultConstruction, Model_ResultField, Model_ResultGroup, Model_ResultPart, and ModelAPI_ResultBody.
protectedvirtualinherited |
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
inlinevirtualinherited |
Reimplemented in ModelAPI_CompositeFeature, ModelAPI_Feature, PartSetPlugin_Part, SketchPlugin_ConstraintMirror, SketchPlugin_MultiRotation, and SketchPlugin_MultiTranslation.
protectedinherited |
