The construction element result of a feature. More...
#include <ModelAPI_ResultParameter.h>
| virtual void | initAttributes ()=0 |
| The generic initialization of attributes. More... | |
| MODELAPI_EXPORT | ~ModelAPI_ResultParameter () |
| Destructor. More... | |
| virtual bool | isConcealed () |
| Returns true if the result is concealed from the data tree (referenced by other objects) More... | |
| virtual void | setIsConcealed (const bool theValue, const bool theForced=false) |
| Sets the result as concealed in the data tree (referenced by other objects) More... | |
| virtual bool | setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag) |
| Enables/disables the result. More... | |
| virtual bool | isDisabled () |
| Returns the result is disabled or not. More... | |
| virtual std::shared_ptr< GeomAPI_Shape > | shape () |
| Returns the shape-result produced by this feature (or null if no shapes) More... | |
| Returns all the vertices of this result. More... | |
| Returns all the edges of this result. More... | |
| Returns all the wires of this result. More... | |
| Returns all the faces of this result. More... | |
| Returns all the shells of this result. More... | |
| Returns all the solids of this result. More... | |
| On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More... | |
| static const std::string & | VALUE () |
| The computed value attribute Id. More... | |
| static const std::string & | STATE () |
| The computational error attribute Id. More... | |
| static const std::string & | COLOR_ID () |
| Reference to the color of the result. More... | |
| static const std::string & | DEFLECTION_ID () |
| Reference to the deflection of the result. More... | |
| static const std::string & | TRANSPARENCY_ID () |
| Reference to the transparency of the result. More... | |
| static const std::string & | ISO_LINES_ID () |
| static const std::string & | SHOW_ISO_LINES_ID () |
| static const std::string & | SHOW_EDGES_DIRECTION_ID () |
| static const std::string & | BRING_TO_FRONT_ID () |
| Reference to the BringToFront flag of the result. More... | |
| virtual void | init () |
| virtual void | erase () |
| removes all fields from this feature More... | |
Protected Attributes | |
| bool | myIsDisabled |
| the result is disabled: removed for the user, but keeps the general info More... | |
Provides a shape that may be displayed in the viewer. Intermediate, light result that in many cases produces a result on the fly.
| ModelAPI_ResultParameter::~ModelAPI_ResultParameter | ( | ) |
inlinevirtual |
Implements ModelAPI_Object.
inlinestatic |
inlinestatic |
inlinestatic |
pure virtual |
Reimplemented from ModelAPI_Result.
Implemented in Model_ResultParameter.
inlinestaticinherited |
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
The double value is used. The value is in [0, 1] range
The bool value is used.
Reimplemented in Model_ResultBody, and Model_ResultConstruction.
The disabled result does not participate in any calculation and visualization: like it was removed. But it keeps the general parameters: colors, visibility, etc.
| theThis | pointer to this object, needed to generate all events if it is necessary |
| theFlag | makes disabled if it is true |
Reimplemented in Model_ResultBody, and Model_ResultPart.
Reimplemented in Model_ResultConstruction, Model_ResultField, Model_ResultGroup, Model_ResultPart, and ModelAPI_ResultBody.
protectedvirtualinherited |
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
inlinevirtualinherited |
Reimplemented in ModelAPI_CompositeFeature, ModelAPI_Feature, PartSetPlugin_Part, SketchPlugin_ConstraintMirror, SketchPlugin_MultiRotation, and SketchPlugin_MultiTranslation.
protectedinherited |
