| Model_FieldStep (ModelAPI_ResultField *theParent, int theId) | |
| virtual ModelAPI_ResultField * | field () const |
| virtual int | id () const |
| virtual std::wstring | name () |
| Returns a GUI name of this step. More... | |
| Returns the group identifier of this object. More... | |
| Request for initialization of data model of the object: adding all attributes. More... | |
| virtual bool | isDisabled () |
| virtual void | init () |
| virtual void | erase () |
| removes all fields from this feature More... | |
inlinevirtual |
Implements ModelAPI_ResultField::ModelAPI_FieldStep.
inlinevirtual |
inlinevirtual |
inlinestaticinherited |
inlinevirtualinherited |
Implements ModelAPI_Object.
Reimplemented in ModelAPI_CompositeFeature, ModelAPI_Feature, PartSetPlugin_Part, SketchPlugin_ConstraintMirror, SketchPlugin_MultiRotation, and SketchPlugin_MultiTranslation.
