Feature for creation of interpolation curve from set of points. More...
#include <BuildPlugin_Interpolation.h>
| BuildPlugin_Interpolation () | |
| virtual void | execute () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | CREATION_METHOD_ID () |
| Attribute name of creation method. More... | |
| static const std::string & | CREATION_METHOD_BY_SELECTION_ID () |
| Attribute name of creation method by selection. More... | |
| static const std::string & | CREATION_METHOD_ANALYTICAL_ID () |
| Attribute name of creation method analytical. More... | |
| static const std::string & | BASE_OBJECTS_ID () |
| Attribute name of base objects. More... | |
| static const std::string & | CLOSED_ID () |
| Attribute name of closed flag. More... | |
| static const std::string & | REORDER_ID () |
| Attribute name of reorder flag. More... | |
| static const std::string & | USE_TANGENTS_ID () |
| Attribute name of use tangents flag. More... | |
| static const std::string & | TANGENT_START_ID () |
| Attribute name of tangent for start point. More... | |
| static const std::string & | TANGENT_END_ID () |
| Attribute name of tangent for end point. More... | |
| static const std::string & | XT_ID () |
| Attribute name of x(t) equation. More... | |
| static const std::string & | YT_ID () |
| Attribute name of y(t) equation. More... | |
| static const std::string & | ZT_ID () |
| Attribute name of z(t) equation. More... | |
| static const std::string & | MINT_ID () |
| Attribute name of min t. More... | |
| static const std::string & | MAXT_ID () |
| Attribute name of max t. More... | |
| static const std::string & | VARIABLE_ID () |
| Attribute of parameter name of variable. More... | |
| static const std::string & | VALUE_ID () |
| Attribute of parameter name of value. More... | |
| static const std::string & | EXPRESSION_ERROR_ID () |
| Attribute of parameter expression error. More... | |
| static const std::string & | NUMSTEP_ID () |
| Attribute name of number of steps. More... | |
| static bool | CLOSED_DEFAULT () |
| Default value of the closed attribute. More... | |
| static const std::string & | ARGUMENTS_ID () |
| List of references to the arguments of this expression. More... | |
| void | evaluate (std::string &theError) |
| Evaluates the expression x(t), y(t),z(t) in value table. More... | |
| void | updateCoordinates () |
| Update coordinates x,y,z. More... | |
Protected Attributes | |
| std::string | outErrorMessage |
| Output error for python interpreter. More... | |
| BuildPlugin_Interpolation::BuildPlugin_Interpolation | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
| [in] | theID | identifier of changed attribute. |
protected |
protected |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
protected |
