ModelAPI_AttributeReference Class Referenceabstract
Attribute that contains reference to feature (located in the same document). More...
#include <ModelAPI_AttributeReference.h>
Inheritance diagram for ModelAPI_AttributeReference:
virtual void setValue (ObjectPtr theObject)=0
 Defines the object referenced from this attribute. More...
virtual ObjectPtr value ()=0
 Returns object referenced from this attribute. More...
virtual std::string attributeType ()
virtual ~ModelAPI_AttributeReference ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ~ModelAPI_AttributeReference()
ModelAPI_AttributeReference::~ModelAPI_AttributeReference ( )
◆ ModelAPI_AttributeReference()
ModelAPI_AttributeReference::ModelAPI_AttributeReference ( )
◆ setValue()
virtual void ModelAPI_AttributeReference::setValue ( ObjectPtr  theObject)
pure virtual
Implemented in Model_AttributeReference.
◆ value()
virtual ObjectPtr ModelAPI_AttributeReference::value ( )
pure virtual
◆ typeId()
static std::string ModelAPI_AttributeReference::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeReference::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
