API for the attribute that contains several strings in the array inside. More...
#include <ModelAPI_AttributeStringArray.h>
| virtual MODELAPI_EXPORT int | size ()=0 |
| Returns the size of the array (zero means that it is empty) More... | |
| virtual MODELAPI_EXPORT void | setSize (const int theSize)=0 |
| Sets the new size of the array. The previous data is erased. More... | |
| virtual MODELAPI_EXPORT void | setValue (const int theIndex, const std::string theValue)=0 |
| Defines the value of the array by index [0; size-1]. More... | |
| virtual MODELAPI_EXPORT std::string | value (const int theIndex)=0 |
| Returns the value by the index. More... | |
| virtual MODELAPI_EXPORT std::string | attributeType () |
| Returns the type of this class of attributes, not static method. More... | |
| virtual MODELAPI_EXPORT | ~ModelAPI_AttributeStringArray () |
| To virtually destroy the fields of successors. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| static MODELAPI_EXPORT std::string | typeId () |
| Returns the type of this class of attributes. More... | |
| MODELAPI_EXPORT | ModelAPI_AttributeStringArray () |
| Objects are created for features automatically. More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
protected |
pure virtual |
Implemented in Model_AttributeStringArray.
pure virtual |
pure virtual |
pure virtual |
inlinestatic |
Reimplemented in GeomData_Dir, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelection, and Model_AttributeSelectionList.
| theBlock | a block value |
By default it is true.
protectedvirtualinherited |
Reimplemented in GeomData_Dir, GeomData_Point, GeomData_Point2D, GeomData_Point2DArray, Model_AttributeBoolean, Model_AttributeDocRef, Model_AttributeDouble, Model_AttributeDoubleArray, Model_AttributeImage, Model_AttributeIntArray, Model_AttributeInteger, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelectionList, Model_AttributeString, and Model_AttributeTables.
protectedinherited |
