ModelAPI_AttributeStringArray.h
20#ifndef ModelAPI_AttributeStringArray_H_
21#define ModelAPI_AttributeStringArray_H_
23#include <ModelAPI.h>
24#include <ModelAPI_Attribute.h>
26#include <string>
27
32{
33public:
35 MODELAPI_EXPORT virtual int size() = 0;
36
38 MODELAPI_EXPORT virtual void setSize(const int theSize) = 0;
39
41 MODELAPI_EXPORT virtual void setValue(const int theIndex,
42 const std::string theValue) = 0;
43
45 MODELAPI_EXPORT virtual std::string value(const int theIndex) = 0;
46
48 MODELAPI_EXPORT static std::string typeId()
49 {
50 return "StringArray";
51 }
52
54 MODELAPI_EXPORT virtual std::string attributeType();
55
57 MODELAPI_EXPORT virtual ~ModelAPI_AttributeStringArray();
58
59protected:
61 MODELAPI_EXPORT ModelAPI_AttributeStringArray();
62};
63
65typedef std::shared_ptr<ModelAPI_AttributeStringArray> AttributeStringArrayPtr;
66
67#endif
API for the attribute that contains several strings in the array inside.
Definition: ModelAPI_AttributeStringArray.h:32
virtual MODELAPI_EXPORT std::string attributeType()
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeStringArray.cpp:23
static MODELAPI_EXPORT std::string typeId()
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeStringArray.h:48
virtual MODELAPI_EXPORT std::string value(const int theIndex)=0
Returns the value by the index.
Definition: ModelAPI_AttributeStringArray.cpp:34
virtual MODELAPI_EXPORT ~ModelAPI_AttributeStringArray()
To virtually destroy the fields of successors.
Definition: ModelAPI_AttributeStringArray.cpp:29
virtual MODELAPI_EXPORT void setSize(const int theSize)=0
Sets the new size of the array. The previous data is erased.
virtual MODELAPI_EXPORT int size()=0
Returns the size of the array (zero means that it is empty)
virtual MODELAPI_EXPORT void setValue(const int theIndex, const std::string theValue)=0
Defines the value of the array by index [0; size-1].
