SketchPlugin_Trim Class Reference
Feature for creation of a new constraint trimming object. More...
#include <SketchPlugin_Trim.h>
Inheritance diagram for SketchPlugin_Trim:
virtual void execute ()
virtual bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro() More...
virtual bool isPreviewNeeded () const
 Reimplemented from ModelAPI_Feature::isPreviewNeeded(). More...
 SketchPlugin_Trim ()
virtual std::string processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Apply information of the message to current object. It fills selected point and object. More...
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Split constraint kind. More...
static const std::string & SELECTED_OBJECT ()
static const std::string & SELECTED_POINT ()
 Start 2D point of the split segment. More...
static const std::string & PREVIEW_OBJECT ()
 The value parameter for the preview object. More...
static const std::string & PREVIEW_POINT ()
static std::string group ()
void keepCurrentFeature ()
void restoreCurrentFeature ()
Entities for split:
◆ SketchPlugin_Trim()
SketchPlugin_Trim::SketchPlugin_Trim ( )
◆ ID()
static const std::string & SketchPlugin_Trim::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_Trim::getKind ( )
Implements ModelAPI_Feature.
◆ SELECTED_OBJECT()
static const std::string & SketchPlugin_Trim::SELECTED_OBJECT ( )
inlinestatic
◆ SELECTED_POINT()
static const std::string & SketchPlugin_Trim::SELECTED_POINT ( )
inlinestatic
◆ PREVIEW_OBJECT()
static const std::string & SketchPlugin_Trim::PREVIEW_OBJECT ( )
inlinestatic
◆ PREVIEW_POINT()
static const std::string & SketchPlugin_Trim::PREVIEW_POINT ( )
inlinestatic
◆ execute()
void SketchPlugin_Trim::execute ( )
Remove reference of this feature to feature used in preview, it is not necessary anymore as trim will be removed after execute
points of trim
find features that should be deleted (e.g. Middle Point) or updated (e.g. Length)
◆ initAttributes()
void SketchPlugin_Trim::initAttributes ( )
Implements ModelAPI_Object.
◆ isMacro()
virtual bool SketchPlugin_Trim::isMacro ( ) const
true
◆ isPreviewNeeded()
virtual bool SketchPlugin_Trim::isPreviewNeeded ( ) const
Returns false. This is necessary to perform execute only by apply the feature
◆ getAISObject()
AISObjectPtr SketchPlugin_Trim::getAISObject ( AISObjectPtr  thePrevious)
◆ processEvent()
std::string SketchPlugin_Trim::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
Implements ModelAPI_IReentrant.
◆ isInHistory()
inlinevirtualinherited
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
inlinestaticinherited
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
