SketchPlugin_BSpline Class Reference
Feature for creation of the B-spline curve in the sketch. More...
#include <SketchPlugin_BSpline.h>
Inheritance diagram for SketchPlugin_BSpline:
virtual SKETCHPLUGIN_EXPORT const std::string & getKind ()
virtual SKETCHPLUGIN_EXPORT void attributeChanged (const std::string &theID)
 SketchPlugin_BSpline ()
virtual SKETCHPLUGIN_EXPORT bool isFixed ()
virtual SKETCHPLUGIN_EXPORT void execute ()
virtual SKETCHPLUGIN_EXPORT bool customAction (const std::string &theActionId)
 Updates the B-spline curve. More...
virtual bool isCopy () const
 Returns true of the feature is a copy of other feature. More...
virtual bool isInHistory ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 B-spline feature kind. More...
static const std::string & START_ID ()
 start point of B-spline curve More...
static const std::string & END_ID ()
 end point of B-spline curve More...
static const std::string & POLES_ID ()
 list of B-spline poles More...
static const std::string & WEIGHTS_ID ()
 list of B-spline weights More...
static const std::string & DEGREE_ID ()
 attribute to store the degree of B-spline More...
static const std::string & KNOTS_ID ()
 list of B-spline knots More...
static const std::string & MULTS_ID ()
 list of B-spline multiplicities More...
static const std::string & ADD_POLE_ACTION_ID ()
 name for add pole action More...
static const std::string & AUXILIARY_ID ()
 Reference to the construction type of the feature. More...
static const std::string & EXTERNAL_ID ()
 Reference to the external edge or vertex as a AttributeSelection. More...
static const std::string & COPY_ID ()
 Reference to the copy type of the feature. More...
static const std::string & PARENT_ID ()
 Reference to the parent feature if exist. More...
static const int SKETCH_LINE_WIDTH_AUXILIARY ()
 Width of the auxiliary line. More...
static const int SKETCH_LINE_WIDTH ()
 Width of the line. More...
static const int SKETCH_LINE_STYLE_AUXILIARY ()
 Style of the auxiliary line. More...
static const int SKETCH_LINE_STYLE ()
 Style of the line. More...
static std::string group ()
virtual void initDerivedClassAttributes ()
 Initializes attributes of derived class. More...
virtual bool isPeriodic () const
 Return true if the B-spline curve is periodic. More...
bool addPole (const int theAfter)
 Add new pole after the pole with the given index. More...
virtual void initDerivedClassAttributes2 ()
 Initializes attributes of derived class which were added recently. More...
void keepCurrentFeature ()
void restoreCurrentFeature ()
◆ SketchPlugin_BSpline()
SketchPlugin_BSpline::SketchPlugin_BSpline ( )
◆ ID()
static const std::string & SketchPlugin_BSpline::ID ( )
inlinestatic
◆ START_ID()
static const std::string & SketchPlugin_BSpline::START_ID ( )
inlinestatic
◆ END_ID()
static const std::string & SketchPlugin_BSpline::END_ID ( )
inlinestatic
◆ getKind()
virtual SKETCHPLUGIN_EXPORT const std::string & SketchPlugin_BSpline::getKind ( )
Implements ModelAPI_Feature.
◆ attributeChanged()
void SketchPlugin_BSpline::attributeChanged ( const std::string &  theID)
Reimplemented from SketchPlugin_BSplineBase.
◆ initDerivedClassAttributes()
void SketchPlugin_BSpline::initDerivedClassAttributes ( )
◆ isPeriodic()
virtual bool SketchPlugin_BSpline::isPeriodic ( ) const
inlineprotectedvirtual
Implements SketchPlugin_BSplineBase.
◆ POLES_ID()
static const std::string & SketchPlugin_BSplineBase::POLES_ID ( )
inlinestaticinherited
◆ WEIGHTS_ID()
static const std::string & SketchPlugin_BSplineBase::WEIGHTS_ID ( )
◆ DEGREE_ID()
static const std::string & SketchPlugin_BSplineBase::DEGREE_ID ( )
◆ KNOTS_ID()
static const std::string & SketchPlugin_BSplineBase::KNOTS_ID ( )
◆ MULTS_ID()
static const std::string & SketchPlugin_BSplineBase::MULTS_ID ( )
◆ ADD_POLE_ACTION_ID()
static const std::string & SketchPlugin_BSplineBase::ADD_POLE_ACTION_ID ( )
◆ isFixed()
bool SketchPlugin_BSplineBase::isFixed ( )
Reimplemented from SketchPlugin_Feature.
◆ execute()
void SketchPlugin_BSplineBase::execute ( )
◆ customAction()
bool SketchPlugin_BSplineBase::customAction ( const std::string &  theActionId)
[in]theActionIdaction key id (in following form: Action::Index)
false in case the action not performed.
◆ addPole()
bool SketchPlugin_BSplineBase::addPole ( const int  theAfter)
◆ AUXILIARY_ID()
static const std::string & SketchPlugin_SketchEntity::AUXILIARY_ID ( )
◆ EXTERNAL_ID()
static const std::string & SketchPlugin_SketchEntity::EXTERNAL_ID ( )
◆ COPY_ID()
static const std::string & SketchPlugin_SketchEntity::COPY_ID ( )
◆ PARENT_ID()
static const std::string & SketchPlugin_SketchEntity::PARENT_ID ( )
◆ SKETCH_LINE_WIDTH_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH_AUXILIARY ( )
◆ SKETCH_LINE_WIDTH()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_WIDTH ( )
Width of the line.
◆ SKETCH_LINE_STYLE_AUXILIARY()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE_AUXILIARY ( )
◆ SKETCH_LINE_STYLE()
static const int SketchPlugin_SketchEntity::SKETCH_LINE_STYLE ( )
Style of the line.
◆ initAttributes()
void SketchPlugin_SketchEntity::initAttributes ( )
Implements ModelAPI_Object.
Reimplemented in SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, and SketchPlugin_MacroEllipticArc.
◆ isExternal()
virtual bool SketchPlugin_SketchEntity::isExternal ( ) const
inlinevirtualinherited
◆ isCopy()
virtual bool SketchPlugin_SketchEntity::isCopy ( ) const
◆ initDerivedClassAttributes2()
virtual void SketchPlugin_SketchEntity::initDerivedClassAttributes2 ( )
Reimplemented in SketchPlugin_Projection.
◆ isInHistory()
◆ canBeDisplayed()
true
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
