Feature for creation of extrusion along a path. More...
#include <FeaturesPlugin_Loft.h>
| virtual void | execute () |
| FeaturesPlugin_Loft () | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | FIRST_OBJECT_ID () |
| Attribute name for first object selected. More... | |
| static const std::string & | SECOND_OBJECT_ID () |
| Attribute name for second object selected. More... | |
Pipe creates extrusion of objects along a path. It produces the following results from objects: Vertex -> Edge Edge -> Face Wire -> Shell Face -> Solid
| FeaturesPlugin_Loft::FeaturesPlugin_Loft | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
