Feature for movement objects along one or two axes an arbitrary number of times, making a copy every time. More...
#include <FeaturesPlugin_MultiTranslation.h>
| virtual FEATURESPLUGIN_EXPORT const std::string & | getKind () |
| virtual FEATURESPLUGIN_EXPORT void | execute () |
| virtual FEATURESPLUGIN_EXPORT void | initAttributes () |
| FeaturesPlugin_MultiTranslation () | |
| std::wstring | name () |
| Multi-translation kind. More... | |
| static const std::string & | OBJECTS_LIST_ID () |
| Attribute name of referenced objects. More... | |
| static const std::string & | AXIS_FIRST_DIR_ID () |
| Attribute name of a first direction. More... | |
| static const std::string & | STEP_FIRST_DIR_ID () |
| Attribute name of step for the first direction. More... | |
| static const std::string & | NB_COPIES_FIRST_DIR_ID () |
| Attribute name of number of copies for the first direction. More... | |
| static const std::string & | USE_SECOND_DIR_ID () |
| Attribute name for use second dir. More... | |
| static const std::string & | AXIS_SECOND_DIR_ID () |
| Attribute name of a second direction. More... | |
| static const std::string & | STEP_SECOND_DIR_ID () |
| Attribute name of step for the second direction. More... | |
| static const std::string & | NB_COPIES_SECOND_DIR_ID () |
| Attribute name of number of copies for the second direction. More... | |
| FeaturesPlugin_MultiTranslation::FeaturesPlugin_MultiTranslation | ( | ) |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
