Feature for applying of Boolean Smash operation. More...
#include <FeaturesPlugin_BooleanSmash.h>
Public Types | |
| enum | OperationType { BOOL_CUT , BOOL_FUSE , BOOL_COMMON , BOOL_FILL , BOOL_SMASH } |
| virtual void | execute () |
| FeaturesPlugin_BooleanSmash () | |
| OperationType | operationType () |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | OBJECT_LIST_ID () |
| Attribute name of main objects. More... | |
| static const std::string & | TOOL_LIST_ID () |
| Attribute name of tool objects. More... | |
| static const std::string & | USE_FUZZY_ID () |
| Attribute name of use fuzzy parameter. More... | |
| static const std::string & | FUZZY_PARAM_ID () |
| Attribute name of fuzzy parameter. More... | |
| void | loadNamingDS (std::shared_ptr< ModelAPI_ResultBody > theResultBody, const std::shared_ptr< GeomAPI_Shape > theBaseShape, const ListOfShape &theTools, const std::shared_ptr< GeomAPI_Shape > theResultShape, const GeomMakeShapePtr &theMakeShape) |
| Load Naming data structure of the feature to the document. More... | |
| void | storeResult (const ListOfShape &theObjects, const ListOfShape &theTools, const GeomShapePtr theResultShape, int &theResultIndex, std::shared_ptr< GeomAlgoAPI_MakeShapeList > theMakeShapeList, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList) |
| Store result shape if it is not empty and increase results counter. More... | |
| void | initVersion (const std::string &theVersion, const std::shared_ptr< ModelAPI_Attribute > theObjectsAttr=std::shared_ptr< ModelAPI_Attribute >(), const std::shared_ptr< ModelAPI_Attribute > theToolsAttr=std::shared_ptr< ModelAPI_Attribute >()) |
| Initialize version field of the Boolean feature. More... | |
| bool | processAttribute (const std::string &theAttributeName, GeomAPI_ShapeHierarchy &theObjects, ListOfShape &thePlanesList) |
| Process SelectionList attribute and fill the objects hierarchy. More... | |
| bool | processObject (const GeomAlgoAPI_Tools::BOPType theBooleanType, const GeomShapePtr &theObject, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr()) |
| Perform Boolean operation of the object with the tools. More... | |
| bool | processCompsolid (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompsolidHierarchy, const GeomShapePtr &theCompsolid, const ListOfShape &theTools, const ListOfShape &thePlanes, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr()) |
| Perform Boolean operation of the Compsolid with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More... | |
| bool | processCompound (const GeomAlgoAPI_Tools::BOPType theBooleanType, GeomAPI_ShapeHierarchy &theCompoundHierarchy, const GeomShapePtr &theCompound, const ListOfShape &theTools, const double theFuzzy, int &theResultIndex, std::vector< ModelAPI_Tools::ResultBaseAlgo > &theResultBaseAlgoList, ListOfShape &theResultShapesList, GeomShapePtr theResulCompound=GeomShapePtr()) |
| Perform Boolean operation of the Compound with the tools In case of theResultCompound is not empty, the result of Boolean operation is added to this compound, and corresponding ResultBody is not generated. More... | |
| GeomShapePtr | keepUnusedSubsOfCompound (const GeomShapePtr &theResult, const GeomAPI_ShapeHierarchy &theObjectsHierarchy, const GeomAPI_ShapeHierarchy &theToolsHierarchy, std::shared_ptr< GeomAlgoAPI_MakeShapeList > theMakeShapeList) |
| Process unused sub-shapes of compounds. More... | |
Static Protected Member Functions | |
| static const std::string & | BOP_VERSION_9_4 () |
| static void | resizePlanes (const ListOfShape &theObjects, ListOfShape &thePlanes, std::shared_ptr< GeomAlgoAPI_MakeShapeList > &theMakeShapeList) |
| Resize planes to fit them to the bounding box of the given lins of objects. More... | |
| FeaturesPlugin_BooleanSmash::FeaturesPlugin_BooleanSmash | ( | ) |
inlinestatic |
Feature kind.
inlinevirtual |
Implements ModelAPI_Feature.
inlinestatic |
inlinestatic |
Reimplemented from FeaturesPlugin_Boolean.
inlinestaticinherited |
protectedinherited |
The version is initialized for newly created features, not read from previously stored document.
false if something went wrong
staticprotectedinherited |
Keep the compound hierarchy, but merge top-level compounds into a single compound and add the result of the FUSE operation.
inlinevirtualinherited |
inlineinherited |
Implements ModelAPI_Object.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
